Latest: BlackIrish05009
Overall: 3574
Visitors: 122
Total: 122
02: Event Calendar
26: Event Calendar
63: My Account
78: Pictures
96: Event Calendar
104: Event Calendar
112: Event Calendar
118: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Installing seats...
Installing seats...
MWDesigns
MWDesigns
Post Post subject: Installing seats...
Posted: Mon Oct 08, 2007 08:23 PM
Ok so the project is going SLOOOOWWW! But I have finally gotten a chance to doing a little work.
OK the question; (kinda for Don but I welcome ANY input)
Looking at the Project Baja build on the Chirco website, I noticed you build a seat bace straight to the roll cage and the center hump. I have chosen a different route. Mainly because I haven't done the cage yet. I am using the universal seat mount (without the sliders) from Chirco.
www.chircoestore.com/c...ts_id=4934
I have fab'ed a way to mount the seat that I have to the mount.
Now the question, besides the obvious bolt it to the pan, what is the best way to mount the "frame" to the pan? Should I remove the factory seat mount to gain a better mounting spot or just mount the front "legs" in front of the factory stuff?
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
Wiggins
Wiggins
Post Post subject: Re: Installing seats...
Posted: Tue Oct 09, 2007 06:16 AM
Sorry I missed this topic.
These seat mounts are very universial so mounting them is up to you.
I just like to see the mounting points re-inforced so the first time you hit a bump,, the seat mount does not tear out.
We have seen people weld flat strap under the car and to the bottom of the tunnel the to the outside of the pan to help the strength.
Any other opions out there?
General Manager
www.chirco.com
MWDesigns
MWDesigns
Posted: Tue Oct 09, 2007 06:17 PM
Thanks Don.
I didn't think about reinforcing the mounts. Do you think I should spend the time taking the stock mount out or just work around it? I finished up mounting the seat to the seat mount last night, I'll try to get some picts up tonight.
Graphic Designer,
Army OIF Veteran
Wiggins
Wiggins
Posted: Tue Oct 09, 2007 07:16 PM
Yoy probally can work around it so you don't weaken the floor pan when popping out the spot welds.
General Manager
www.chirco.com
MWDesigns
MWDesigns
Posted: Tue Oct 09, 2007 07:38 PM
sounds good! thanks
Graphic Designer,
Army OIF Veteran
T_Town_Baja
T_Town_Baja
Posted: Tue Oct 09, 2007 09:33 PM
Mike -
If possible, see if you could mount your frame to the pan, but also fab up a way to integrated it with the factory mounts. Thus giving your seat mounts a larger footprint on the pan. This will give you strength and a better mouting 'apparatus'.
Possibly tie your mounts into the pan, and run cross plates to tie into the factory mounts...just a thought
Blaine
MWDesigns
MWDesigns
Posted: Tue Oct 09, 2007 11:57 PM
Laughing the apparatus will be secure! Laughing
I think I have enough room to work around the factory stuff. I'll weld some flat stock to the pan and bolt it up. Eventually I think I'd like to tie it in to the cage, when I get one, like Don's "project Baja"
Graphic Designer,
Army OIF Veteran
Wiggins
Wiggins
Posted: Wed Oct 10, 2007 02:52 PM
You will like getting a cage.
General Manager
www.chirco.com
MWDesigns
MWDesigns
Posted: Thu Oct 11, 2007 06:05 AM
OK I finally got some pictures of the apparatus
Graphic Designer,
Army OIF Veteran
Posted: Thu Oct 11, 2007 07:16 AM
Looking good, Mike! NICE seats!
Posted: Thu Oct 11, 2007 07:49 AM
BUGBOMB... Quick tip remove all that Tar crap underliner stuff. Do it now that you have the car open and dirty. I left mine on the hump.
MWDesigns
MWDesigns
Posted: Thu Oct 11, 2007 08:17 AM
I am planning on taking out all of the tar crap. Once I'm done doing that I'm going to spray it with Durabak, it's a bed liner stuff. It's about $80-120 a gallon, depending on the color and it comes in about 16 different colors. A lot of the Jeep guys do something like it.
The BUGBOMB plate is from my 1st Baja, I just stuck it on this one to tow it so wouldn't get pulled over. I think the new one will be BUGBOM2, if it's available.
Graphic Designer,
Army OIF Veteran
No new posts VW Volkswagen & Baja Bug General Discussion New bucket seats 1 vwboat 2253 New bucket seats
 Tue Nov 27, 2012 09:09 PM
biblethumpncop View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What seats do you have? 10 Ejbbal21 5722 What seats do you have...
 Wed Apr 18, 2012 02:55 AM
Hyperwrx View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Seats rock laterally. 3 Gunpilot 2680 Seats rock laterally.
 Thu Sep 01, 2011 06:59 AM
Gunpilot View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Poly Seats 0 chickenpants 1672 Poly Seats
 Thu Dec 09, 2010 04:09 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Local source for poly seats 4 chickenpants 2242 Re: Local source for p...
 Wed Sep 29, 2010 02:15 PM
