Visitors: 119
Total: 119
18: Event Calendar
27: Home
29: Event Calendar
37: Event Calendar
61: Pictures
63: Event Calendar
73: Event Calendar
79: Home
108: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 6'' wider beam
6'' wider beam
cperry2704
cperry2704
Post Post subject: 6'' wider beam
Posted: Mon Oct 08, 2007 04:45 AM
if i wanted to try and build a 6'' wider front end for my 66 baja....how might i go about it?
Post Post subject: Re: 6'' wider beam
Posted: Mon Oct 08, 2007 06:10 AM
Are you planning on staying with stock trailing arms and brakes? If so, just buy the beam (and possibly longer torsions for the wider beam), longer tierods, then put all your stuff on it. You can buy a Warrior beam from Chirco (and elsewhere). They're a +6 beam. If you want more suspension travel at the same time, now it starts costing a fair amount of $$$. Longer travel shocks, longer trailing arms, blah blah blah.
That help any?
cperry2704
cperry2704
Posted: Mon Oct 08, 2007 06:27 AM
yeah i was thinking of staying with stock arms and brakes for now
Wiggins
Wiggins
Posted: Mon Oct 08, 2007 04:05 PM
If you have a ball joint frond end, you will need to do a custom beam or replace your frame head. A standard warrior beam will not bolt up to a B/J frame head.
Bugzyla, chime in any time.
General Manager
www.chirco.com
www.chircoestore.com
Posted: Mon Oct 08, 2007 04:13 PM
I build conversion beams (link pin) that bolt into a balljoint frame head. You just need the parts off of a l/p beam to finish the job. I can build any width you want. The warrior beams are very nice, my only complaint is the adjusters are put in where the lowest setting is a lot higher than stock. I put my adjusters in so that the lowest setting is stock and you have plenty of adjustment to go up from there.
Posted: Mon Oct 08, 2007 07:10 PM
DOH! I forgot to ask if he had a ball joint or link pin beam.
Wiggins
Wiggins
Posted: Tue Oct 09, 2007 06:03 AM
Yah, but you have a cool truck. Smile
Link pin was only up to 1965 and he said he has a 1966.
I'm on my seventh year doing this everyday and some times i miss these things.
General Manager
www.chirco.com
GABug
GABug
Posted: Sat Oct 13, 2007 03:42 AM
Not to hijack but here I go anyway Very Happy
I picked up a thing cheap, gonna use the arms n spindles on the bug. Im going to widen the beam also using beams from both the bug and thing. Is there a good step by step out there?
MWDesigns
MWDesigns
Posted: Sat Oct 13, 2007 05:55 AM
BugZyla
How much do you charge for your beems? I wanted to do a wider front on mine but didn't want to go through the trouble of changing the frame head yet. b/j front end still.
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
Posted: Sat Oct 13, 2007 06:12 AM
I can do a widened b/j beam for $250 plus shipping, bare. Add $75 for torsions. I can also do a link pin beam that bolts to the balljoint frame head for $300 bare.
MWDesigns
MWDesigns
Posted: Sat Oct 13, 2007 06:29 AM
forgive me for being dumb, but by torsions do you mean the springs inside?
Graphic Designer,
Army OIF Veteran
Crash
Crash
Posted: Sun Oct 14, 2007 11:01 PM
so for your conversion beam how did you clearance the balljoint bolt pattern where it intersects the kingpin beam tubes? I built one but it was such a pain to make I just never made any available.
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
25 Kreed 28842 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Bent beam 1 cperry2704 1772 Bent beam
 Tue May 30, 2017 03:38 AM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Need a rebuild on my link pin beam 2 wideopenmotorsports 2999 Re: Need a rebuild on ...
 Wed May 18, 2011 01:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion bearing in side bj beam 11 1969Type1BAJA 5595 Re: bearing in side bj...
 Tue Feb 23, 2010 07:56 AM
1969Type1BAJA View latest post
No new posts VW Volkswagen & Baja Bug General Discussion cut the center beam 1 1969Type1BAJA 1815 Re: cut the center bea...
 Sun Dec 06, 2009 09:33 PM
