Latest: thelataviayoung
Overall: 3584
Members: 1
Visitors: 105
Total: 106
 Members:
01: kordan80 > Home
21: Event Calendar
38: Event Calendar
82: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Torsion Bar Adjustment
XXJUPITERXX1
XXJUPITERXX1
Post Post subject: Torsion Bar Adjustment
Posted: Sat Oct 06, 2007 05:30 AM
I'm looking to get maybe 2 inches of lift on my front end by cranking on the torsion bars, im new to this Bug thing, and am unabel to find the torsion bars =/ also, how much should i adjust them and also do i only need a wrench, r so i need special tools/kits?
Thanks all
Wiggins
Wiggins
Post Post subject: Re: Torsion Bar Adjustment
Posted: Sat Oct 06, 2007 06:47 AM
Do you have a stock front end?
General Manager
www.chirco.com
www.chircoestore.com
XXJUPITERXX1
XXJUPITERXX1
Posted: Sat Oct 06, 2007 07:17 PM
Yes
Posted: Sat Oct 06, 2007 08:57 PM
Then you have a couple of options:
1, Buy an off road beam with adjusters welded in.
2, Cut your beam and weld in adjusters.
3, Cut your beam, rotate the center section 1/4 " and reweld.
XXJUPITERXX1
XXJUPITERXX1
Posted: Sat Oct 06, 2007 09:43 PM
Any suggestions on an off road beam with adjusters welded in from Chirco?
sandshark
sandshark
Posted: Sat Oct 06, 2007 09:51 PM
I was thinking about cutting and turning my front beam, what about the rear IRS? Is that a cut and turn job too? Or is there away to do it at the outside ends, since the rear has t-bars (I think) instead of leaf packs? Mine's a '75, by the way, with those tubes poking out in front of the rear wheels, which I'd like to eliminate by converting to the flush plates w/ shorter bars to clear bigger tires. Can raising the rear end be done as part of the conversion, thus saving me the trouble of cutting and turning?
Wiggins
Wiggins
Posted: Sat Oct 06, 2007 09:56 PM
For the rear of the car you are on the right track.
Check this article about my old car
http://www.chircoestore.com/catalog/article_info.php?articles_id=50
I did the same thing to get rid of the long torion bars.
General Manager
www.chirco.com
sandshark
sandshark
Posted: Sat Oct 06, 2007 10:24 PM
Thanks Don! Are the 501148S plates the correct p/n for a '75? What p/n are the red grommets and SA bushings? One more thing, does this job (front and rear) just increase the ride height? Or does it add a little to suspension travel too? Appreciate the info!
Posted: Sat Oct 06, 2007 11:44 PM
Here is the one I am using:
www.chircoestore.com/c...ts_id=4598
It is 6" wider, so you need a new spring pack. They also have stock width beams.
www.chircoestore.com/c...ts_id=1065
For the rear IRS, here is a build which they did the same thing. Also no welding in the rear if you already have IRS:
www.chircoestore.com/c...icles_id=2
Posted: Sat Oct 06, 2007 11:47 PM
Oops, Don responded while I was typing and occasionally working. Embarassed
XXJUPITERXX1
XXJUPITERXX1
Posted: Sat Oct 06, 2007 11:59 PM
I have a 69 with ball joint, not link pin, so im assuming this:
www.chircoestore.com/c...ts_id=1068
would be the equivalent?
Posted: Sun Oct 07, 2007 12:29 AM
Kind of as good as it gets for ball joint if you want to do a beam. 2 other options:
Lift spindles from blind chicken racing. Keep a softer ride, does not tax the ball joints.
www.blindchickenracing..._parts.htm
Get thing trailing arms and spindle. Heavier duty than type 1 and built in lift.
No new posts VW Volkswagen & Baja Bug General Discussion Coils Ver Torsion bar 12 Darn_Near 6728 Coils Ver Torsion bar
 Wed Oct 21, 2015 06:29 PM
thing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear torsion housing adjuster 3 ghettodish 4639 Rear torsion housing a...
 Fri Jul 01, 2011 12:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion Link Pin stiffer front torsion leafs 6 nvlandshark 4946 Re: Link Pin stiffer f...
 Sat Jan 16, 2010 03:03 PM
nvlandshark View latest post
No new posts VW Volkswagen & Baja Bug General Discussion how to re-set the torsion bars in the rear ? 2 sweetcars 2396 Re: how to re-set the ...
 Sun Dec 20, 2009 12:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion Help...need torsion leaves 6 bajawarrior 2620 Help...need torsion le...
 Tue Oct 27, 2009 05:52 AM
bajawarrior View latest post
