Visitors: 118
Total: 118
02: Event Calendar
44: Pictures
49: Pictures
58: Event Calendar
73: Event Calendar
77: Pictures
87: Event Calendar
88: Pictures
92: Pictures
108: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- a baja
a baja
cjsanders
cjsanders
Post Post subject: a baja
Posted: Thu Oct 04, 2007 02:16 AM
i want something i can go play in the mud with and stuff like that...so with that said a want a bug that can stand up to 31 inch tires and pull em good...whats a good year model? my grandpa has got a vw graveyard so it wont be a problem. it dont have to be nothin special
I LOVE BAJAS
fatalifeaten
fatalifeaten
Post Post subject: Re: a baja
Posted: Thu Oct 04, 2007 02:33 AM
Get something on an IRS pan , '69 on (NO SUPERS!). Cut the head off and weld on a Link pin pan head. Go to town from there. Tires and motor/trans combinations are going to be up to you, but I'd humbly suggest a nice peppy 1915 dual carb motor and a nice beefed-up T1 trans or a bus trans.
--Harlan Ellison
cjsanders
cjsanders
Posted: Thu Oct 04, 2007 02:49 AM
ok....but i dont want to build a motor quite that big...i want something thats reliable...yet also fun
I LOVE BAJAS
fatalifeaten
fatalifeaten
Posted: Thu Oct 04, 2007 03:11 AM
Reliability is all about durability. If you take the time to build it as robustly as possible and build it to match the way you'll be driving it, a big motor will last a very long time. 1915 isn't all that big anymore when guys are running 2.3l turbo motors on the street daily. You might look into a stroker motor too. Bigger crank, smaller cylinders so you can have thicker cylinder walls for more heat dissipitaiton The torque from a stroker motor would also be beneficial for churning them 31's.
You can run a smaller displacement engine all day long if that's what you're comfy with, but it may not feel as peppy with big tires. In the end, it's completely up to you, but if you do a little research up front you're going to be far happier with the end result.
--Harlan Ellison
StinkBug333
StinkBug333
Posted: Thu Oct 04, 2007 05:54 AM
With a smaller engine (1600) your going to have it rev'ed out higher and for longer periods (Trying to get more power) accualy puting more stress on it. With a larger engine you get more reliable power because your not stressing it as much... a 1915 is as good as it gets non stroked. But the preferance is totaly up to you and how much $$$ you have.
if your not sooo interested in goin super fast (70mph @ 5500RPM) just get a gearbox thats geared low and youll never have to worry about turning those 31's
If your gonna be Dumb
YOU BETTER BE TUFF!
cjsanders
cjsanders
Posted: Thu Oct 04, 2007 09:17 PM
thanks....anyone else
I LOVE BAJAS
klwdesigns
klwdesigns
Posted: Thu Oct 04, 2007 10:33 PM
I have a 1600, stock swing axle and 235's on the rear. It's a dog. it's not fun to play in, gets stuck easily.
cjsanders
cjsanders
Posted: Thu Oct 04, 2007 10:59 PM
well i can get ahold of a bus transaxle...and i can rebiuld a 1600..so would that have me set?
I LOVE BAJAS
cjsanders
cjsanders
Posted: Thu Oct 04, 2007 11:03 PM
i want to build it cheap to...i want bumpers and safety stuff like that but i really want to keep it under about 3 or 4 grand
I LOVE BAJAS
T_Town_Baja
T_Town_Baja
Posted: Fri Oct 05, 2007 05:00 AM
For 3-4 Grand, you can by some pretty dang nice bajas already done, with everything you would want. For instance, I picked up a 68' Baja, has a Mofoco 1915 in it, brand new tires all around (31" in rear). Needs a few things, but when its done, I will probly ask $2500 for the car, its in GREAT shape. Perfect for daily driver and offroading.
Blaine
cjsanders
cjsanders
Posted: Fri Oct 05, 2007 03:34 PM
but i want the enjoyment of building it my self...if u no what i mean
I LOVE BAJAS
T_Town_Baja
T_Town_Baja
Posted: Fri Oct 05, 2007 05:17 PM
Oh trust me I know the enjoyment of building my own, but I also know the frustrations AND the budget creep. Building one is a heck of a lot of fun, but it really helps to get one that has been started and work from there.
Blaine
cjsanders
cjsanders
Posted: Fri Oct 05, 2007 10:45 PM
another ?...can i make baja fenders out of stock fenders?
I LOVE BAJAS
MWDesigns
MWDesigns
Posted: Fri Oct 05, 2007 11:16 PM
They used to back in the ol' days. They would take the front fenders flip them around and bolt them right up to the back, do a little trimming and whalla! but as for the front, not that I know of... someone correct me if I'm wrong
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
Posted: Fri Oct 05, 2007 11:24 PM
Eric!! Post a link to your fener thread!!!!!
5 Admin_AzBaja 7135 Baja Bugs on Wiki need...
1568 mufasavnvmc 1013088 Re: what did you do to...
285 MusicManiac 244594 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 300 FREE VW BAJA'S
0 Northmountainauto 1702 Shop Baja
