Latest: ecthemc
Overall: 3567
Visitors: 122
Total: 122
11: Event Calendar
18: Event Calendar
20: Pictures
37: Pictures
49: Pictures
62: Event Calendar
65: Event Calendar
72: Pictures
90: Event Calendar
106: Event Calendar
115: Event Calendar
116: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Manx Project
Manx Project
tucsontim
tucsontim
Post Post subject: Manx Project
Posted: Sun Sep 23, 2007 02:49 AM
I figured I should introduce myself (and my project) before I started posting too much. Kevin pointed me here after I asked him about a part he had for sale.
I've been in AZ for four years now, originally from central coast of CA, but am here for grad school.
I got into watercooled VW's in the late 90's when I helped a friend with a motor swap into his GTi. I bought my manx poor condition in '99, it has taken a lot of work, but has only gotten better. After breaking the pan in half (and band aiding it twice) I didn't trust the car anymore until I completely rebuilt the chassis myself. Which I am finally, after three years sitting, and the last four months of steady work am nearing completion.
It originally had a poorly running 1200, which I swapped a tired 914 1.8L in soon after I bought the car with the advice of Tom Slider of STF and type4secrets fame. I then built a 914 2.0L for the car around 2001.
Enough with the talk, here are some pictures. Before:
Getting started on the teardown / build:
The main reason for the rebuild:
I didn't even realize the severity of this crack in the tunnel until I had it stripped down this far. It was about 2" from meeting up with another crack and making me a permanent part of the tarmac. Good timing!
Here is another, similar repair from three years ago:
It seems the more I get my hands on this car, the less VW it becomes.
I am also planning to replace the tired, old webers with a megasquirt-driven ITB setup and wideband O2. Throttle bodies are from a suzuki hayabusa. New FI setup next to weber carb:
Notice, no floors yet, waiting on a little bit of steel to finish the supports, then will be able to cut the aluminum diamond-plate to size and place. (since has been completed)
Tie in to the front suspension, shouldn't break apart this time... Steering gear is OEM VW, and I wasn't sure I was going to be able to keep it with this frame design. Now that I"ve seen that it does fit, I am not so sure I want to move to the new rack which has less throw and a tighter (too tight?) ratio.
I put the steering wheel on for the fun of it, but it is really easy to move around the garage by just pushing / pulling on the wheel and steering at the same time.
I relocated the shifter further back toward the seats and placed the turning brakes nearby so that driver's hand won't have to move too far to actuate.
Just be sure to grab the right err.. correct knob.
Getting some decent results out of the MIG
11" rotors rear.
11" rotors front. No more beetle brakes, this thing will now be able to stop.
Got bored, so put the body on.
That's the original roll-hoop, will be replaced with a full cage.
No more wonky camber in the rear, HOORAY! Now landing the beast won't be quite as sketchy.
This is the 924 tachometer that will be replacing the 914 speedo.
This was a bit of a surprise: 14" of clearance up front! I knew I'd built it a little higher by mounting the front axle lower, but the geometry introdcued by my agressive caster setting compunded this. Unfortunately this height will probably ruin the car's trackworthiness. That's ok though, my next project is a dedicated road car.
Likewise, 15" at the low point of the engine (exhaust pipes).
This was taken from just in front of the rear tire. With the front at full lock, you can see how much the tire leans over. This is a result of the agressive caster to try to relieve the understeer "feature" of a car with 165's up front, 275's in back, and a 25-75 weight distribution. It also has a fair bit of toe-out on the rear axle that I am going to keep for a while to see how it behaves.
The next steps are to: run brake lines and build the cage (which was supposed to be this weekend, but the tube didn't show up). Then I can go about doing the small fab work for the FI.
That's it for now. Might make it out to the bugtoberfest, but I don't think I will have the FI done by then...
Post Post subject: Re: New member
Posted: Sun Sep 23, 2007 03:21 AM
Nice work, and welcome to da board!
Posted: Sun Sep 23, 2007 05:51 AM
I like it!
Posted: Sun Sep 23, 2007 06:01 AM
WOW!!! Shocked
fatalifeaten
fatalifeaten
Posted: Sun Sep 23, 2007 07:26 AM
Welcome Smile
--Harlan Ellison
Posted: Sun Sep 23, 2007 04:21 PM
Welcome!! nice fab work. I don't know if you have seen the forum talk on the october bbq event. Everyone is welcome. food provided by Chirco in Tucson. If you would like to come please email me or Mykul your street address and we can get you some flyers. It is in Scottsdale Oct. 28.
Posted: Sun Sep 23, 2007 05:51 PM
welcome, is this the first manx at azbaja ? nice work....
tucsontim
tucsontim
Posted: Sun Sep 23, 2007 08:12 PM
Thanks for the praise, it really always has been a work in progress. I'd like to get it closer to finished so I can start building a street car. I grew up fabricating some interesting things so I have plenty of background with structural design and mechanical knowledge.
I don't know if I can make the BBQ, the wife is very pregnant with our first, and she is already upset that I have been gone so many weekends recently. I am an instructor with ACNA, was at buttonwillow two weeks ago, and on the weekend of the 6th will be at sears point. (I can't resist a day at the track.) I was also planning to be in PHX today to build the rollcage for the car, but the steel didn't show up; I will probably do it next Sunday.
I would like to get the car out to the Chirco event since they have helped me a bit with the project and it is just up the street. We'll have to see if it is roadworthy by then. Like hell if I'm going to tow it there.
Posted: Sun Sep 23, 2007 09:11 PM
the wife is pregnant with our 2nd, and she is already...... Hmmm seems like I* hve the same type of problem, I have to tow my car to Tucson as she ill not ride in the bja and more...
ACNA?
tucsontim
tucsontim
Posted: Sun Sep 23, 2007 09:32 PM
ACNA?
Audi Club.
tucsontim
tucsontim
Posted: Mon Mar 03, 2008 01:51 AM
some new pictures:
Post Post subject: Re: Manx Project
Posted: Mon Mar 03, 2008 02:27 AM
is that an org. manx or just a manx style?
That thing looks sweet
tucsontim
tucsontim
Posted: Mon Mar 03, 2008 02:33 AM
A very close copy.
Posted: Mon Mar 03, 2008 02:39 AM
i think once i get my baja done and finish my 68 ranchero, i wanna get a fiberglass manx for a street cruiser (a lot of crap for a 14 year old, man i gotta slow down:))
1170 Dalton 253108 My 69 project
 Wed Dec 06, 2017 01:38 AM
No new posts Projects and Builds Project Purple People Eater 3 Yasha7fold 1156 Project Purple People ...
 Wed Jul 12, 2017 08:03 PM
Yasha7fold View latest post
88 Dirtjunkie 48305 Project II
65 PaDan 46527 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 6385 Re: new project
