Latest: ecthemc
Overall: 3567
Visitors: 127
Total: 127
19: Home
28: Event Calendar
62: Event Calendar
97: Event Calendar
109: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Anyone bored right NOW? In a pickle in NE Mesa.... HELPPP!!
Post Post subject: Anyone bored right NOW? In a pickle in NE Mesa.... HELPPP!!
Posted: Sat Sep 15, 2007 08:28 PM
So, I'm installing a new top end on my car today. Had some help lined up, but he had some work-related issues pop up today and doesn't appear to be available. I've got a cooled garage, the heads are off, the right side cylinders and one piston are off, and I'd like some supervision for re-assembly, as I've never done this before. I'm right behind the Home Depot at Power/McKellips. Anyone have some time early this afternoon to drop by and lend a hand for a bit?? Pleeeeeeze??? I'd really like to get this thing together today.
Thanks,
Tony
480-797-8389 cell
Post Post subject: Re: Anyone bored right NOW? In a pickle in NE Mesa.... HELP
Posted: Sun Sep 16, 2007 12:25 AM
Were you able to figure it out?
Post Post subject: Re: Anyone bored right NOW? In a pickle in NE Mesa.... HELPPP!!
Posted: Sun Sep 16, 2007 12:36 AM
Well, I've got one side together- hopefully it's all good. I preoiled the cylinders, ran a light bead of red RTV around the cylinder bases, and just did the very light initial torque of the head. There's no gaskets at the cylinder base or between the cylinder and head, right? (my kit came with none, and there didn't seem to be any installed on disassembly).
keep your fingers crossed... I probably won't be able to work on the other side until later tonight.
OH, and I pulled the pistons out and spaced out the ring gaps. Oil controls both up (but spread out some) and a 120* gap on the compression rings...
Posted: Sun Sep 16, 2007 01:51 AM
Sounds good so far. And yes there are no gaskets.
Posted: Sun Sep 16, 2007 01:53 AM
PS
Remember that oil that you lined the cylinders with? Don't freak when it smokes a little when you first fire it up. It could take a bit for the rings to seat also.
Posted: Sun Sep 16, 2007 04:10 AM
Some day we need to do an engine build clinic. I have no clue about the VW engines too.
Posted: Sun Sep 16, 2007 07:29 AM
Well, things took a turn for the worse. Got to the second side, and when I pulled the #4 cylinder, I found that one circlip had failed, and the wrist pin had both wallowed out the piston AND dug a nice oval groove in the cylinder. Plus, I think some idiot bent the rod on that cylinder (that would be me) trying to get the wrist pin out.
Can you say niiiiiiiiiice???
Time to pull the motor. Pisser since the only time I've driven the car is home from the previous owner's house...
The upside is that at least I'll know what I've got for a motor. So far, it's got CB 044 heads. We'll see what else is inside.
Posted: Sun Sep 16, 2007 07:31 AM
Myk may have a spare to sell....
Posted: Sun Sep 16, 2007 12:56 PM
Those are nice heads. Did Scott make it over there?
Posted: Sun Sep 16, 2007 03:52 PM
If your careful you can change the rod without splitting the case. I have a spare rod.
Posted: Sun Sep 16, 2007 04:09 PM
Yeah, Scott made it over right after I pulled the #4 cylinder and found the damage. He's recommending that I pull the motor and have a look inside. I'm thinking I wouldn't mind, so at least I'll know where I'm at with the motor. I don't really want to have to worry every time I drive it if there was something else going on in there, and the next mash of the pedal is going to cause catastrophic failure. Also, I'd like to know what else is IN this motor (cam, etc.)...
anhedonite
anhedonite
Posted: Tue Sep 18, 2007 04:27 AM
Im all for this. I could have gotten an engine for dirt cheap, but I didn't want to have to put it back together...I would love to know more about engine builds.
Posted: Tue Sep 18, 2007 04:30 AM
MMMMmmmm...
Next how to thread maybe?
Posted: Tue Sep 18, 2007 04:57 AM
Im savin for that nw enegine of mine.
maybe we can use it as a build demo???
No new posts New Members The new guy in Mesa
My sons 1st car project
2 Adub 966 The new guy in Mesa
 Sat Jan 28, 2017 04:45 AM
No new posts VW Volkswagen & Baja Bug General Discussion new here. Any street guys from Mesa area? 2 ExtremeBean 2421 new here. Any street g...
 Fri Apr 10, 2015 12:36 AM
JWHracing View latest post
No new posts New Members Salvo says "Hello!" from Mesa, Az... 5 Salvo 1835 Salvo says "Hello!" fr...
 Thu Sep 19, 2013 06:15 PM
No new posts Events and Get Togethers World Wide Table Mesa Clean up 1 perrib 2654 Table Mesa Clean up
 Thu Sep 23, 2010 12:14 AM
No new posts Events and Get Togethers World Wide MESA 5/14/2010 3 jamesr6168 2391 MESA 5/14/2010
 Wed May 19, 2010 06:35 AM
