Latest: Smokey4
Overall: 3593
Visitors: 76
Total: 76
04: My Account
18: Memberships
58: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- wiring
wiring
caversmoon
caversmoon
Post Post subject: wiring
Posted: Sun Sep 16, 2007 03:30 AM
I just got the blinkers to work. All that I have left to do is the wiper moter. I tested the moter and it still works. Looks like the switch is bad. I pick up a new one from B.A.P. tomorrow. Then if every thing goes right my friend will tow the bug to Bugzila for the pan transfer and upgrades. Tom Laughing
Post Post subject: Re: wiring
Posted: Sun Sep 16, 2007 04:18 AM
the trick is the park side of the wipers. You need to drop the volts or it will run past park and never stop.
caversmoon
caversmoon
Posted: Sun Sep 16, 2007 04:20 AM
Will the new switch do that. I am running 12 hot to the 30 of the switch.
caversmoon
caversmoon
Posted: Sun Sep 16, 2007 04:24 AM
I am also going to run 102 inch wipp for the cb. What is the usual way to atach it. I was thinking of just drilling a hole in the bumper. Tom
Posted: Sun Sep 16, 2007 04:34 AM
CB wip on my car is on a welded tab on the back bumper. as for the the wipper park you will need some sort of resistor to drop your Volts for the park. At 12volts the motor is turning so fast that it will run past the park and restart. I have to some times reach out the window on my Baja to stop the wipers as they do run on.
caversmoon
caversmoon
Posted: Sun Sep 16, 2007 04:39 AM
When I aplied the power to the moter it seamed to go back and forh. Did you soder a resistor in line with the power or did you do it after the switch. My bug is a 68. I am taking it to bugzila to put it on a 66 pan. I have not baja the bug yet. That one of the things I am going to do. but first I am instaling disk brakes in the back and I am doing the lift. That is all I have the money for at this time. Tom
Posted: Sun Sep 16, 2007 04:51 AM
! used a ballest resitor (White Block) lymouth/Dodge...It runs from the switch to the wire in the motor and it's blade conectors no soldering. It will need to by a high watt resitor too.
caversmoon
caversmoon
Posted: Sun Sep 16, 2007 04:56 AM
Where did you get it.?
Posted: Sun Sep 16, 2007 07:28 AM
www.mopartsracing.com/...strore.gif
or
any parts store around 6 bucks or so or evan the junk yard. on most any mopar from 1972 to early 80's
Posted: Sun Sep 16, 2007 03:48 PM
If its a 12 volt motor you shouldnt have to put the resistor inline. Only if its a 6 volt motor. I believe Tom has a 12 volt motor, and should work just by wiring it up right.
Posted: Sun Sep 16, 2007 06:49 PM
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5792 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
Efi to carb
4 bugzapper 2985 Wiring
 Tue Jun 28, 2016 03:16 PM
28 seanoflinn1 11492 Re: Can Somone take a ...
 Mon Jun 14, 2010 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Think I might have a wiring problem? 5 Roadrunner 2863 Re: Think I might have...
 Sun Aug 03, 2008 10:35 PM
sandshark View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VDO Guage Wiring Diagrams 1 BugZyla.com 2821 Re: VDO Guage Wiring D...
 Sat Feb 16, 2008 11:21 PM
jamesr6168 View latest post
