Latest: strike77
Overall: 3575
Visitors: 124
Total: 124
03: Home
05: Event Calendar
11: Pictures
20: Event Calendar
21: Home
50: Event Calendar
67: Event Calendar
78: Event Calendar
123: Contact Admin
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Doctors visit
Doctors visit
azhunter
azhunter
Post Post subject: Doctors visit
Posted: Sat Jun 24, 2006 06:19 AM
So I went to see the doctor today. He said I need my head ported. What do you all think?
What do you all think? Can I be saved? Shocked
Post Post subject: Re: Doctors visit
Posted: Sat Jun 24, 2006 07:45 AM
I also think you need to see the eye Dr. it's a bit Fuzzy.
69bapbaja
69bapbaja
Posted: Sat Jun 24, 2006 08:52 AM
take your valves set them in there spots one at a time. Put valve grindin compound on the seat of the valve attach the other end too a 8mm fuel rummber line with clampthen attaytch that too a drill. Then with a slow motions in and out with slow power on the drill. wipe them off re aply then go a little dit faster done. move on to the next. Poor man valve job...
saved a couple heads this way.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
azhunter
azhunter
Posted: Sat Jun 24, 2006 05:06 PM
These heads are off of the engine I traded for. It had been sitting for about 10 years, not locked up. I tore it down to clean it up,the assembly lube turned to cosmoline, and didn't like the 1/4 in step under the exhaust valve. So, i got out my dremel and carbide bits and started shaving. Now I can get my finger all the way through the port. The pics were merely a before and after shot. A 3 angle grind is in order as well. Has anyone tried this other than me? If so, I'm curious of the results. They are pretty blurry huh?
bajasam96
bajasam96
Posted: Sat Jun 24, 2006 06:21 PM
Ive ported an armload of these aircooled heads, stay with the exhaust side. Only touch the intake if you know exactally what your doin. Other than that as long as you were even with each port it'll turn out pretty sweet. I read an article about 2 years ago claiming that a mild port job and (kads/bugspray) was improving 22hp on the dyno...
azhunter
azhunter
Posted: Sat Jun 24, 2006 08:13 PM
I have an idea for a "redneck" flow meter. I'll let ya know if it works.
69bapbaja
69bapbaja
Posted: Sun Jun 25, 2006 06:36 AM
know you know you'll lose low end when increasing the exhaust flow? great for the street fast not to good pushin you up a hill.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
No new posts VW Volkswagen & Baja Bug General Discussion Suprise visit... 7 Hedrock 3986 Re: Suprise visit...
 Mon Jun 09, 2008 11:21 PM
oldfart View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Az visit
28 Leatherneck 6648 Re: Az visit
 Wed Jan 16, 2008 08:39 PM
Leatherneck View latest post
