Visitors: 112
Total: 112
52: Event Calendar
64: Pictures
97: Event Calendar
112: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Adjustable Spring Plates on my baja....
r8rfan66
r8rfan66
Post Post subject: Adjustable Spring Plates on my baja....
Posted: Sat Sep 08, 2007 07:20 PM
Hello!
I'm trying to install adjustable spring plates on my body-off 62 baja project. The plates didn't come with directions, and I can't find much info on my searches. My question is, Are the stock torsion bar cover plates used with these? And is there any tips anyone can offer that's done this before? This is a street legal baja with s/a trans... Thanks again! I've been gettin through this project with a lot of help from this site. I'm a newbie to the VW scene for about 9 months now and have definately benefited from your expertise! (spent a grip of $$ too! lol)
Post Post subject: Re: Adjustable Spring Plates on my baja....
Posted: Sat Sep 08, 2007 09:25 PM
The simple answer is that depends. There are a few different types of covers, some with holes and some without holes. So here's what you've gotta ask yourself, "Dose it look like it will work?" If not then go buy some new covers.
r8rfan66
r8rfan66
Posted: Sat Sep 08, 2007 10:18 PM
by "holes", you mean for the torsion bars??
Posted: Sat Sep 08, 2007 11:09 PM
I have not seen the set you have, but I think you need a spacer for the cover. I'm not sure how thick the adjustable spring plate is. Pictures are always worth 10,000 words Smile
Posted: Sun Sep 09, 2007 12:11 AM
Aye laddie! Wink AZBAJA's right, I believe the adjustable spring plates are thicker too.
Posted: Sun Sep 09, 2007 12:28 AM
Install them with out the torshion bar first. this will let you move them up and down etc. to find the range of motion. if the torshion plate hits the spring plate wyou will need to install a spacer or some washers or somthing like that under the cover. You will also need to get longer bolts. Make sure you get good quality grade 8 bolts.
4 Admin_AzBaja 5565 Baja Bugs on Wiki need...
1568 mufasavnvmc 887903 Re: what did you do to...
285 MusicManiac 215508 Re: Baja sightings
0 Northmountainauto 24 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1066 Baja hiding in Chandle...
