Visitors: 139
Total: 139
55: Event Calendar
121: Event Calendar
125: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- HELP PLEASE!
HELP PLEASE!
Bubba
Bubba
Post Post subject: HELP PLEASE!
Posted: Tue Sep 04, 2007 02:48 AM
Got me a problem: Evil or Very Mad
I took the top half of the motor off to clean and paint. Laughing
Carb was off for a month. Sad
Put it back and car ran like you know what. Evil or Very Mad Mad
Took it off and cleaned it, put it back and same thing. Evil or Very Mad
Adjusted carb, can't make it better. Mad
Replaced points and cond., no change. Mad
Replaced plugs, no change. Evil or Very Mad Evil or Very Mad
Dis. was not moved.
Vacuum leaks checked without spraying carb cleaner.
I still have no acceleration while driving, it revs to a point and stops. While setting still acceleration is fine.
WHAT THE HECK IS IT?
Post Post subject: Re: HELP PLEASE!
Posted: Tue Sep 04, 2007 03:17 AM
Are you sure the plug wires are connected properly?
Posted: Tue Sep 04, 2007 06:00 AM
make sure you cable is opening up the carb all the way.
fatalifeaten
fatalifeaten
Posted: Tue Sep 04, 2007 08:17 PM
X2
--Harlan Ellison
ridinthedunes
ridinthedunes
Posted: Wed Sep 05, 2007 03:39 AM
x3^^
Bubba
Bubba
Posted: Fri Sep 07, 2007 03:12 AM
Cable is opening the carb all the way.
What if the throtle pump diaphram has a hole in it?
Posted: Fri Sep 07, 2007 08:10 AM
that could be bad. is it sucking air or blowing black smoke?
Bubba
Bubba
Posted: Fri Sep 07, 2007 01:47 PM
It does sound like it's sucking air, but no black smoke. Backfire with flames out of the carb sometimes though.
Posted: Fri Sep 07, 2007 04:19 PM
Are you SURE the distributor wasn't moved??? I'd put a timing light on it if it was me.
Posted: Fri Sep 07, 2007 07:58 PM
If you can drive it over to my place next week I can take a look at it. 1 to 4 in the after noon is good as the baby is sleeping then and a loud VW will help fill her pampers.
For SG if you have a video camera and a budy film it and put it on you tube and link to it here.
Posted: Fri Sep 07, 2007 11:00 PM
pssttt..Eric..Hes in Virginia!!!
ok you need to remove the dist cap. now find the timing mark on the crank pulley.
got it? good!
sounds like the dist is 180* out with flames out the carb.
you wil need to hand ctrun the crank pully to the right untill the timing mark is on top at 0*.
trhis will either be tdc or bdc.
I do not recall, do you have a vac or 009 dist?
if its a 009, there is a #1 cyl notch in the top of the dist housing. line that up with the timing mark on the pully along with the dist rotor pointin at the same location as the other 2 marks ( dist notch and pully mark).
if you are at tdc, then this will set you close to 0* on timing. then adjust from there.
if not. repeat but rotate the crank around again till the timing mark and pulley line up together again.
I will through some pics up here...
Posted: Fri Sep 07, 2007 11:19 PM
heres a pic of the timing notch on a 009 dist.
heres a vid of turnin to 31 cyl tdc with rotor , pulley, and dist notch all lined up...
ok guys, laugh. 2 arms are broken and the other two a both lefts..yes, the cell phone made me jumpy dang it!!!
Posted: Fri Sep 07, 2007 11:21 PM
Laughing Laughing Laughing Laughing Laughing
my own vid makes me ROFLMFAO!!!
HKOWACZ
HKOWACZ
Posted: Sat Sep 08, 2007 12:58 AM
WHO CALLED? LOL
"IT'S A BAJA THING"
Posted: Sat Sep 08, 2007 02:02 AM
HKOWACZ wrote:
WHO CALLED? LOL
my mortgage guy... Rolling Eyes
