Visitors: 116
Total: 116
20: Event Calendar
21: Event Calendar
48: Event Calendar
59: Event Calendar
61: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Getting Started (hopefully this weekend)
anhedonite
anhedonite
Post Post subject: Getting Started (hopefully this weekend)
Posted: Fri Sep 07, 2007 01:37 AM
So I am finally getting started..
Here is a bad picture of my car that I took with my cell phone:
There currently is no motor, no seats, no guages....basically its just a shell.
What I was thinking, since this is my first project car, is to pull off the body, and sand down and paint the frame first, and start doing the work with the body off (brake lines, engine etc). This weekend I was planning on working on taking off the body and starting the sanding process, but I haven't decided whether to prime and paint the frame, or to use something like huculiner or rhino liner to actually coat the frame.
I was wondering if anyone had any thoughts on where they would start this project, on what I should do with the frame, or if what I am planning seems like a bad idea in general. Like I said..this is brand new to me, and I am trying to do the least expensive parts now, so I can save up for a decent motor. My intention is to make this off road capable as well as a daily driver. I like to rock climb and am planning on trying out for the mountain rescue team, so I would like something that can handle off road well, and be street legal as well.
Thanks
Post Post subject: Re: Getting Started (hopefully this weekend)
Posted: Fri Sep 07, 2007 04:04 AM
It sort of depends on the condition of your pan (frame) as far as rust goes. The pan floorboards are typically dented up, and the battery tray is frequently rusted through the floor. If the pan is structurally sound, you can have it sandblasted for about $50 I'm told (top and bottom), and then you can apply (or pay to have it done) bedliner or POR-15, which is a similar material, to the pan.
Taking the body off and starting on the pan is the most common starting point. The pan, suspension, transmission, and finally the engine usually, then the body to finish it off. The pan and attached components can cost you LOTS of $$$$ if you want to spend it.
Good luck!
Posted: Fri Sep 07, 2007 04:45 AM
I would start on the pan also. Strip it down to a bare pan and then determine if you need to install new pan sections or not. If so do this before you have it blasted. Sand blasting is $60 out at Soutwest Sandblasting & Painting in Chandler. You can then coat it with your choice of paint, POR15 or Herculiner, I recomend the herculiner. The start re-assebmling it from there.
anhedonite
anhedonite
Posted: Fri Sep 07, 2007 05:34 AM
Thanks guys!
Daryll, how difficult is it to apply the herculiner? Did you spray it on, or roll it on? I think would rather go that route.
Posted: Fri Sep 07, 2007 05:39 AM
We spray it. If you dont want to mess with it, we can spray it for $200 and that includes the cost of 4 qts od herculiner at $25 per. Or you can also roll it on.
No new posts Events and Get Togethers World Wide box canyon area this weekend.... 0 ikill6453 709 box canyon area this w...
 Thu Apr 13, 2017 03:49 AM
ikill6453 View latest post
No new posts Events and Get Togethers World Wide presidents weekend ......ITS ON....
feb 18 to feb 20
4 ikill6453 1407 Re: presidents weekend...
 Sat Feb 04, 2017 02:55 PM
No new posts VW Volkswagen & Baja Bug General Discussion presidents day weekend 2017 0 ikill6453 873 presidents day weekend...
 Wed Feb 01, 2017 11:59 PM
No new posts New Members presidents weekend 2017 0 ikill6453 845 presidents weekend 201...
 Wed Feb 01, 2017 11:58 PM
No new posts VW Volkswagen & Baja Bug General Discussion Jerome VW jamboree this weekend?? 6 sandbuggy 2116 Jerome VW jamboree thi...
 Wed Sep 16, 2015 07:33 PM
