Visitors: 115
Total: 115
20: Event Calendar
23: Links
51: Event Calendar
54: Event Calendar
58: Event Calendar
63: Event Calendar
79: Home
89: Event Calendar
91: Home
102: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Solid Fuel Line Question
r8rfan66
r8rfan66
Post Post subject: Solid Fuel Line Question
Posted: Sun Sep 02, 2007 08:07 AM
Is it necessary to use steel line to replace the fuel line that runs through the tunnel? Will rubber fuel line work? If not, what diameter tubing should I use, and where could I find it?? Thanks as always for your help!
fatalifeaten
fatalifeaten
Post Post subject: Re: Solid Fuel Line Question
Posted: Sun Sep 02, 2007 08:10 AM
Run hard lines. Rubber will dry out and/or runs the risk of chafing or otherwise failing, and you end up with gas in your tunnel, which is bad ummmmkay? You can order replacement hard lines pretty much everywhere.
--Harlan Ellison
HKOWACZ
HKOWACZ
Posted: Sun Sep 02, 2007 03:30 PM
YOU CAN PURCHASE PRE-MADE STEEL LINES OR IF YOUR BROKE LIKE MOST OF US ARE, NAPA AUTO PARTS SELLS STEEL BRAKE LINE BY THE FOOT, MEASURE AND REPLACE. 1/4 OR 5/16 IS FINE. BUT PLEASE MAKE SURE YOU SECURE IT SO IT DOESNT RUBE METAL TO METAL OR YOU WOULD BE IN THE SAME BOAT AS INSTALLING A RUBBER LINE, IT WILL EVENTULLAY WARE A SMALL HOLE IN IT AND LEAK. THAT WOULD MAKE A TUNNEL BOMB LOL!!!!!!!!!
"IT'S A BAJA THING"
Posted: Sun Sep 02, 2007 04:22 PM
The factory size is 1/4 steel line and is all you need unless your pushing a motor above 2000cc, then step up to 5/16. If you dont want to go through the hassle of running it inside the tunnel again, there is room to run the line on the floor right next to the brake line, just make sure you secure it with clamps that have a rubber or plastic insulator. I would defiantely use steel though.
HKOWACZ
HKOWACZ
Posted: Mon Sep 03, 2007 04:48 PM
Lime? no Lemon?
IM SORRY. I DONT UNDERSTAND? Confused
"IT'S A BAJA THING"
r8rfan66
r8rfan66
Posted: Mon Sep 03, 2007 06:31 PM
I think I'll try running it next to the brake line like you suggested Bugzyla.. I know it's probably difficult to feed a replacement line through the tunnel, but is it THAT difficult? I mean, is it worth the effort to try? This fuel line id for my baja, and it seems more practical to run it next to the brake line, but if it's safer inside the tunnel, I'd like to go that route... thanks again everyone!
Posted: Mon Sep 03, 2007 06:58 PM
If you are going to run it inside the tunnel, you will need to cut some holes in the side to attach the new line where the old one was anchored so it doesnt rattle or rub on the shift tube or other stuff. Personally, I usually just run them on the floor, much easier.
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 7920 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2657 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5476 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 3454 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
No new posts VW Volkswagen & Baja Bug General Discussion super baja question 9 vtbaja 4375 super baja question
 Thu Aug 29, 2013 11:07 PM
