Visitors: 93
Total: 93
14: Pictures
30: Pictures
61: Event Calendar
72: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- need help asap
need help asap
milleraj119
milleraj119
Post Post subject: need help asap
Posted: Sun Sep 02, 2007 04:54 AM
whats the easiest way to pop the torsion arm out iv been poundin at it for houres and it hasent moved a inch
Post Post subject: Re: need help asap
Posted: Sun Sep 02, 2007 06:53 AM
Swing, IRS, front, rear?
Posted: Sun Sep 02, 2007 06:57 AM
last, stop now and do not do any thing else you could get hurt real bad or even killed if you screw this up!!! the rear bars should slide out, I do not thik you unloaded the spring presure in them.
fatalifeaten
fatalifeaten
Posted: Sun Sep 02, 2007 07:06 AM
You have to pry the rear spring plates over the stop on the torsion housing to unload them Once you do that, some PB and a rubber mallet from behind should pop them right off. Use a Pry bar to VERY carefully work the spring plate over the pivot stop on the housing (it'll go downwards.) Before you do this scribe a reference line on the torsion housing of the spring plate location so you know where it was initially (and where you need to sit it when you put it back in).
For fronts, make sure the grub screws are backed off in the center of the beam and you should be able to knock the leaf pack out pretty easily once the trailing arms are off. Again, I'd use a rubber mallet fo rthis.
--Harlan Ellison
Posted: Sun Sep 02, 2007 08:07 AM
put a jack under the spring plate, You do not want it to unload on you when you pop it over the stop.
milleraj119
milleraj119
Posted: Sun Sep 02, 2007 04:49 PM
no no no no no the front torsion arms bottom left i neede to replace a ball joint and i cant get it off
fatalifeaten
fatalifeaten
Posted: Sun Sep 02, 2007 05:39 PM
make sure you got the grub screw out, and then soak it withe pb or penetrating oil. Should pop right off. You may have to disassemble the spindle first.
--Harlan Ellison
Posted: Sun Sep 02, 2007 05:44 PM
some times the front arms get worn in do to bad bearinns sludge etc. etc. We had to use a cum-a-long and 2 polls one time to get the control arms out.
milleraj119
milleraj119
Posted: Mon Sep 03, 2007 01:54 AM
i have the hole spindal everyhting off the crubscrew and everything i have no were to tie the comealong to and im prettymuch trying to get the bottom trailing arm off so i can replace a ball joint but still iv tried and tried for houres to take the mother f$%^&* off and it wont come out please help me out
Posted: Mon Sep 03, 2007 05:15 AM
I'd like to help but at this point I'm kida confused about what you are doing. I think that you are trying to take the front trailing arms off to replace the ball joints. If this it true then you need to remove the "grub" screw on each of the trailing arm and they should pull loose. AZBAJA was saying that he had to wrap a come-a-long around the arm and attach it to a sturdy anchor point (like a pole or another vehicle to get his to pull loose. This can be a real bitch. Sorry about that.
fatalifeaten
fatalifeaten
Posted: Mon Sep 03, 2007 05:18 AM
Heat em up with a torch, PB blaster the hell out of them, soak them over night, etc. They'll come loose eventually.
Your other option's to pull the whole beam out and see if you can get better leverage.
--Harlan Ellison
milleraj119
milleraj119
Posted: Mon Sep 03, 2007 06:46 AM
ya thatnks for all the help dident think all this was gonne be a pain well gonna try agian in the morning
Posted: Mon Sep 03, 2007 07:21 AM
did your read the line Below V V V V
Was that guy awake or what?
Posted: Mon Sep 03, 2007 07:25 AM
Capt. Redundancy strikes again!
Posted: Mon Sep 03, 2007 07:26 AM
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2439 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion NEED HELP ASAP!!! Going to ASVAB TEST 14 nube_w_1970baja 4608 Re: NEED HELP ASAP!!! ...
 Wed Nov 19, 2008 01:39 AM
nube_w_1970baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Daryll, Daryl, Darryll...need your logo ASAP 0 lemorris 1353 Daryll, Daryl, Darryll...
 Tue Aug 26, 2008 05:18 PM
lemorris View latest post
No new posts Events and Get Togethers World Wide DHP needs you - We need pictures of Arizona cars ASAP!!!
17 BugZyla.com 6757 Re: DHP needs you - We...
 Tue Oct 02, 2007 11:47 PM
Wiggins View latest post
