Visitors: 137
Total: 137
59: Event Calendar
61: Home
69: Home
70: Home
82: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Questions about "my" car...
Post Post subject: Questions about "my" car...
Posted: Thu Aug 23, 2007 03:40 AM
Anyone know where I can get some replacement covers for my Racetrim seats in my new baja? They're sunrotted to death. Need black.
Also- how much $$$ and how hard is it to replace T1 CV boots? Gonna need to do that too.
Those two things and a compression check to find out where the sticky ring is (hopefully) and I should be cruisin'... Cool
I say "my" because I ain't picked it up yet (or paid for it for that matter). Laughing
Post Post subject: Re: Questions about "my" car...
Posted: Thu Aug 23, 2007 03:45 AM
TALK TO BAJAWARRIOR,HE COULD FIX THOSE SEATS, BEST AND PROBLY FOR A BETTER PRICE,,
Posted: Thu Aug 23, 2007 03:47 AM
Cool- I'll give Scott a call. Mine could be used for a pattern. They LOOK fine, it's just that when you touch them, they crumble and turn your skin black.
Posted: Thu Aug 23, 2007 05:24 AM
cv boots at BAP for $5 or so.
wet check the cylinders.
drip a small amount of oil through the spark plug hole and crank it around..
Daryll knows how it goes....
Posted: Thu Aug 23, 2007 06:24 AM
Embarassed Razz Razz Razz
T_Town_Baja
T_Town_Baja
Posted: Thu Aug 23, 2007 04:55 PM
I got my Racetrim seats recovered for $60 a piece locally in Tucson.
By the way, good looking baja you picked up!
Blaine
Posted: Thu Aug 23, 2007 04:57 PM
Some old timers like marvel's mystery oil (or trans fluid) to loosen up a stuck ring. Change the oil, put in a 50/50 mix of oil and atf; run it for a few minutes, then change the oil again. DISCLAIMER I have never done this myself, but had it done on a V8 that I bought that was neglected.
Posted: Thu Aug 23, 2007 07:37 PM
I'm planning on running some Marvel/motor oil mixed and driving it some to see what happens. I will probably also do a compression test and see if I can figure out which cylinder(s) are leaking. Hoping I can square it away without a teardown, but we'll see.
Posted: Thu Aug 23, 2007 10:13 PM
What does this accomplish? Is there more to the process that you can explain??
Thanks.
Posted: Fri Aug 24, 2007 06:59 AM
Thanks.
leak down test. I remeber it from chirco and thinkin bugzylla mentioed it once.
Posted: Fri Aug 24, 2007 08:03 PM
Thanks.
Comparing the dry and wet (with oil) compression readings will give you a little more insight on the ring quality. The rings are already in question though. A leak down test is where you fill the cylinder with compressed air via a pressure gage and read the percentage of air lost and where is goes. ie out of the carb=intake valve; exhaust =exhaust valve; blows the dipstick out=rings. You can do that after you narrow it down to a cylinder.
Does that help?
I would probably try the snake oil first. Then do a compression test.
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 4778 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5565 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 2328 Tow Bar questions
 Mon Nov 16, 2015 01:45 PM
No new posts New Members New Guy Questions 6 Apoc 4131 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 8201 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
