Visitors: 119
Total: 119
37: Event Calendar
39: Event Calendar
81: Event Calendar
117: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Battery light, and no power. Part two
ajeden
ajeden
Post Post subject: Battery light, and no power. Part two
Posted: Fri Aug 17, 2007 06:01 AM
Hi
Driving home tonight, my baja just stopped. Turn the key and nothing. Radio/Cd player going crazy; turn the hazards on and the cd stops, also the side lights start to flash??
Check the battery and it's down to about 8volts. If you read part one, you'll know that I have had the little red battery light on; but dim and reading if 17 volts at the alternator terminal amd 12 at the battery.
Just to go a bit more. I have two cables coming from the alternator; the thinest from the little spade connector goes into the wiring loom, which I presume goes to the good old little red light. The other which is thicker, goes to the starter motor; to the selenoid part. From this, two cables go to the battery; a thick black one; which again I resume brings the power to the starter. the other re-charges the battery?
What I am thinking is; could it be the volatge regulator in the alternator? My reason; because the good old little red light??????????
Post Post subject: Re: Battery light, and no power. Part two
Posted: Fri Aug 17, 2007 06:07 AM
Did you check the battery?
Posted: Fri Aug 17, 2007 06:08 AM
Posted: Fri Aug 17, 2007 06:29 AM
SEEMS TO ME THAT YOUR RUNNING OFF THE BATTERY, THE BATTERY STARTS YOUR CAR THEN THE ALT TAKES OVER AFTERSTATING,,RUNS YOU POWER THINGS IN YOUR CAR ,,,LIGHTS STERIO, ECT,,,THE VOLTAGE REGULATOR REGULATES HOW MUCH JUICE FROM THE ALT GOES TO RECHARGE THE BATTERY,,, I THINK YOUR ALT WENT SOUTH,,, IF YOUR LIGHTS WENT DIM AND THINGS CHARGE OR JUMP YOUR BATTERY,,, CHECK YOUR ALT CONNECTION, IF YOUR BATTERY GOES DEADAGAIN ,,,,,,,,BAD ALT
DutchBug
DutchBug
Posted: Fri Aug 17, 2007 11:38 AM
I had the same problem some weeks ago.
It iss probably the regulator.
This device prevents the power to run back from the battery to the alternator when the engine is running low, which would result in all sorts of problems.
Solution is easy. Find the regulator, its an aluminium box placed either on top of the alternator or on the drivers side under the rear seat.
Disconnect (remember wiring or make a photo) and take it out. Open it. There is one screw in the center, (sometimes overpainted but it is there). Spray some wd40 in it. Fiddle a bit with the relays. Let it dry (!).
Reinstall the regulator again, DONE!
Don't know if you guys use this stuff, in Holland there is no workshop without it:
WD40
Here's a pic of mine under the rear seat (hope it's not to big):
Posted: Fri Aug 17, 2007 03:21 PM
Shocked
DutchBug
DutchBug
Posted: Fri Aug 17, 2007 04:28 PM
What? To much? Confused ... Sad
ajeden
ajeden
Posted: Fri Aug 17, 2007 09:45 PM
Thanks guys.
Posted: Sat Aug 18, 2007 03:08 AM
wd40 is conductive,,
ajeden
ajeden
Posted: Sat Aug 18, 2007 05:46 AM
Thanks guys for all the support. I checked it all and the cable from the alternator to the starter motor was the culprit. i changed this and some more plus put a new belt on.
Again thanks Razz Razz Razz Razz Razz Razz
DutchBug
DutchBug
Posted: Sat Aug 18, 2007 05:51 PM
Oh, help, dictionairy Smile
No new posts Projects and Builds Cheap DIY electric power steering
16 Azdrtdog 9064 Cheap DIY electric pow...
 Fri Nov 06, 2015 01:07 AM
No new posts Projects and Builds looking for a part. 0 Dalton 2360 looking for a part.
 Thu Jun 04, 2015 03:26 PM
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 97480 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
what do you use
4 bdrdunes 2887 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion oil light
electrical
5 terribletommy 2126 oil light
 Thu May 22, 2014 08:56 PM
