Latest: strike77
Overall: 3575
Visitors: 138
Total: 138
05: Event Calendar
11: Pictures
16: Event Calendar
20: Event Calendar
26: Event Calendar
38: Event Calendar
41: Event Calendar
58: Event Calendar
78: Event Calendar
84: Event Calendar
90: Event Calendar
91: Event Calendar
96: Pictures
100: Event Calendar
136: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Having problems with weber dual carbs
ridinthedunes
ridinthedunes
Post Post subject: Re: Having problems with weber dual carbs
Posted: Thu Jul 19, 2007 11:24 PM
are all 4 barrels sync'd? or did you just do the from two (2&4), are you SURE the linkage is setup correctly? valves all adjusted properly? excellerator pumps working properly?
Maybe give, in detail, your engine specs, including distributor used, timing, valve lash, jetting (emulsion tube, air, main, idle), and maybe a quick example of how you tuned the carbs.
And I was thinking that only kads like such low pressure, thought that idf's were ok at 5lbs.......
elryano
elryano
Posted: Wed Jul 25, 2007 01:53 AM
i was told idfs only need 3 pounds maybe u need a pressure regulator
Posted: Mon Jul 30, 2007 05:22 PM
elryano wrote:
i was told idfs only need 3 pounds maybe u need a "GOOD" pressure regulator
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 3487 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Dual carbs 11 sandbuggy 6691 Dual carbs
 Sun Jul 14, 2013 02:02 PM
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 7528 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion duel weber 44s value 0 beachmaster 1143 duel weber 44s value
 Sun Nov 27, 2011 06:51 AM
beachmaster View latest post
No new posts VW Volkswagen & Baja Bug General Discussion weber style progressive carbs 2 cruzn57 2724 Re: weber style progr...
 Sat Apr 23, 2011 02:31 PM
cruzn57 View latest post
