Latest: strike77
Overall: 3575
Visitors: 114
Total: 114
48: Event Calendar
68: Event Calendar
89: Event Calendar
91: Event Calendar
97: Event Calendar
98: Event Calendar
106: Event Calendar
107: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- welder suggestion please
r8rfan66
r8rfan66
Post Post subject: welder suggestion please
Posted: Tue Jul 24, 2007 08:32 PM
looking to get a wire feed welder for my garage. I'm looking to get something that is sufficient to handle any job on my 66 baja bug. Any suggestions as what to get as far as power goes? Lookin to spend around the $300-350 range. Thanks all!
Post Post subject: Re: welder suggestion please
Posted: Tue Jul 24, 2007 10:34 PM
I say save up $200 add it to the $350 and get a small 125amp welder w argon shielding gas. don't waste money on a cheesy flux core welder.the flux core welders do not work..... I use a snap-on 120amp. but all the other brands do just as good or better. good luck
Posted: Tue Jul 24, 2007 10:51 PM
Lincoln makes some good inexpensive welders. They are very reliable and parts and supplies are available anywhere. But I am with scott, dont be cheap, buy a good 220 volt welder with gas (I use 75/25 co2 argon mix cuz its cheaper) and you will be happier in the long run. I used to have a 110 volt lincoln flux core, and wished I had saved a little more and got a better one, so I eventually ended up with a MAC Tools 150 amp (made by miller).
r8rfan66
r8rfan66
Posted: Wed Jul 25, 2007 01:39 AM
Just the info I was looking for! I'm glad I didn't pull the trigger on the flux-wire set-up....Thanks again!!
Posted: Wed Jul 25, 2007 09:25 AM
I bought a flext core and it WAS Ok at first. Now that I know that I really did need a welder, I wish that I would have got one that was shielded.
However, it is nice to do quick fixes with 110v. I used outlets at Autozone and Roberts tire (the two places that I broke down in front of). Yes both thought that iI was crazy, but they were both happy to help. Very Happy
Posted: Thu Jul 26, 2007 01:18 AM
yep, i have a 110 welder as well and hate it...but its hard to justify spending so much money on something you only use once and a while... Confused
madman74
madman74
Posted: Thu Jul 26, 2007 01:32 AM
I love my hobart handler 135 its only 110 welder but it works great and has pretty good amount of power compared to most of the little welders. It is sheilded too. But I do like using Darylls welder since it seems to get an ark a little faster.
Oops it broke!
MOCRAWLER417
MOCRAWLER417
Posted: Fri Jul 27, 2007 03:09 AM
i have a miller 210 . it works very well for me. i use it extensively welding tubing on my fabricating projects. its more than 300.00 but well worth it.
No new posts New Members NEW WELDER IN GILBERT 2 BONEY 1941 Re: NEW WELDER IN GILB...
 Thu Apr 28, 2011 01:14 PM
BONEY View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Welder Choice
18 JumpinBruceB 15380 Re: Welder Choice
 Mon Jan 19, 2009 05:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion Which welder is better?
18 Zoom153 13760 Re: Which welder is be...
 Wed Apr 16, 2008 04:59 PM
Sample View latest post
No new posts Club AzBaja (Arizona Chapter) next meeeting location suggestion.... 7 kevin 2553 Re: next meeeting loca...
 Sat May 13, 2006 07:55 AM
Mykul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Anybody know a good/resonable welder? 10 mrscsi 5050 Re: Anybody know a goo...
 Sat May 06, 2006 09:30 AM
