Visitors: 94
Total: 94
04: Pictures
23: Event Calendar
28: Event Calendar
48: Event Calendar
77: Home
78: Home
85: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Having problems with weber dual carbs
trigger
trigger
Post Post subject: Having problems with weber dual carbs
Posted: Tue Jul 17, 2007 03:36 AM
wondering if I need to upgrade my fuel pump
milleraj119
milleraj119
Post Post subject: Re: Having problems with weber dual carbs
Posted: Tue Jul 17, 2007 03:56 AM
discuss what the problems are
trigger
trigger
Posted: Tue Jul 17, 2007 05:21 PM
AT AN IDLE THEY RUN GREAT BUT WHEN YOU REV THE ENGINE THEY CUT OUT.
Posted: Tue Jul 17, 2007 06:28 PM
not enough fuel????just enough for idle???
VIN70
VIN70
Posted: Tue Jul 17, 2007 07:50 PM
what fuel pump you have now? how much pressure?
trigger
trigger
Posted: Tue Jul 17, 2007 07:51 PM
THANKS FOR THE INFO BUT AFTER MORE FUEL STILL CUTTING OUT. GOING TO TRY REJETTING THE CARBS.
trigger
trigger
Posted: Tue Jul 17, 2007 07:52 PM
IT IS RUNNING AT 7-10 PSI
Posted: Tue Jul 17, 2007 09:01 PM
Shocked That's a lot!
What carbs and engine?
trigger
trigger
Posted: Tue Jul 17, 2007 11:24 PM
THIS IS WHAT THE NEW PUMP IS PUTTING OUT, THE OLD ONE WAS 3TO5 PSI. THE CARBS ARE WEBER 44 IDF 2 BBLS AND THE ENGINE IS ABOUT A 1750cc
Posted: Wed Jul 18, 2007 05:09 PM
what size fuel line to the pump. just bacuse you psi. you still might not have the flow the carbs need. try changing over to 3/8 Very Happy Very Happy
trigger
trigger
Posted: Wed Jul 18, 2007 08:15 PM
I ve changed the fuel lines still no improvement. also back the fuel pump down to 5 psi thought i was over fueling.
T_Town_Baja
T_Town_Baja
Posted: Wed Jul 18, 2007 09:58 PM
Pretty sure WEBER's like to run at 2-3psi, anything over that is too much.
I am running a single WEBER 40 IDF on my 1835 and it runs like a raped ape, wouldn't mind duals though.
What main jets are you running? Accelerator pump is functioning correctly?
Blaine
ridinthedunes
ridinthedunes
Posted: Thu Jul 19, 2007 08:25 AM
Have you checked to make sure your jets just aren't clogged?
What exactly is it doing? running rough when you rev it or just trying to die?
More specifics would help to diagnos it.
trigger
trigger
Posted: Thu Jul 19, 2007 06:15 PM
WHEN YOU REV THE ENGINE IT IS RUNNING ROUGH AND BACK FIRING OUT OF ONE CYLINDER, THEINKING IT MAYBE OVERLOADING WITH FUEL. AND I HAVE CHECKED THE JETS ON BOTH.
T_Town_Baja
T_Town_Baja
Posted: Thu Jul 19, 2007 10:15 PM
Did this just start on its own, or have you introduced something new to the motor/ done any new work?
Have you synchronized the dual carbs? Seems to me if only one side is running poorly, it may be that specific carb. If you can narrow it to a specific cylinder, perhaps you have a jetting problem on the barrel of the carb.
Also, you said you run about 5psi, I am almost positive Weber 2bbl only like 2-3psi. Could still be too much pressure for the carbs.
Blaine
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 3784 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Dual carbs 11 sandbuggy 7039 Dual carbs
 Sun Jul 14, 2013 02:02 PM
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 7887 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion duel weber 44s value 0 beachmaster 1199 duel weber 44s value
 Sun Nov 27, 2011 06:51 AM
beachmaster View latest post
No new posts VW Volkswagen & Baja Bug General Discussion weber style progressive carbs 2 cruzn57 2831 Re: weber style progr...
 Sat Apr 23, 2011 02:31 PM
cruzn57 View latest post
