Latest: thelataviayoung
Overall: 3584
Visitors: 140
Total: 140
01: My Account
07: Event Calendar
16: My Account
32: Home
74: My Account
100: Pictures
101: Home
127: Event Calendar
139: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Turn Signals
Turn Signals
sickbaja68
sickbaja68
Post Post subject: Turn Signals
Posted: Mon Jul 16, 2007 04:58 AM
Where is a good place to buy those small square aftermarket turnsignals? And do I need a six prong switch in order to make my flasher relay work? I have a four prong flasher now and a three prong swith on off on. But, I don't think the flasher would work with it cause the flasher wouldn't know which side left or right to signal. Any help in this one would be greatly appreciated.
vwbill
vwbill
Post Post subject: Re: Turn Signals
Posted: Mon Jul 16, 2007 05:11 AM
If the center prong on the switch is common then route power to flasher then to center of switch. Switch position would wend it left thru bulbs to ground or right thru bulbs to ground.
The flasher does not decide which side to flash it makes and breaks the circuit when current flows thru it and heats it up.
William
Posted: Mon Jul 16, 2007 05:13 AM
go to AUTO SAFTY HOUSE( ASH) IN PHOENIX CAN'T FIND THE # FOR YOU JUST CALL INFO AND ASK. THEY CARRY ANYTHING FOR TRAILERS, BUSES TRUCKS ETC. THEY WILL HAVE IT GUARANTEE AND THEY CAN HELP YOU WITH THE FLASHERS.
Posted: Mon Jul 16, 2007 06:41 AM
WALLY WORLD,PEPBOYS AUTOZONE ALL SELL AMBER OR RED LED LIGHTS THAT WORK FINE, I USE A SET FOR MY REAR TURNS MOUNTED TO FIREWALL AND A GOT A NICE SET OF ROUND ONES THAT MOUNT INTO MY TILT FRONT FROM OUR FRIENDS AT CHIRCOS,ALSO LED WITH A NICE RUBBER GASKET TO MOUNT THEM IN. THE LED,S ARE NICE AND BRIGHT, THE OTHER CARS WILL KNOW YOUR INTENTIONS FOR SURE!! I HAVE THESE WIREED THRU A AFTERMARKET TURN SWICH(ALSO FROM CHIRCO, AND THEY WORK GREAT!!THEN WIRE THEM LIKE VWBILL SAID . THESE ARE SMALL AND BRIGHT, EASY TO MOUNT ANY WHERE YOU WOULD LIKE, AND LOOK LIKE A PRO!!
Posted: Mon Jul 16, 2007 05:10 PM
wow chirco has the L.E.D lights. cool they don't burn out from playing in desert. yes call
Chirco.com 1-800-955-9795
No new posts VW Volkswagen & Baja Bug General Discussion Its my turn (picture heavy) 7 blubaron66 5800 Re: Its my turn (pictu...
 Thu May 17, 2012 12:24 AM
blubaron66 View latest post
what are yall's set'ups
7 vindeta 14014 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
No new posts VW Volkswagen & Baja Bug General Discussion cut and turn issues 11 Patzke 3399 Re: cut and turn issue...
 Sat May 31, 2008 09:30 AM
Patzke View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Thanks for a great turn out 5 bajawarrior 2677 Re: Thanks for a great...
 Tue Apr 22, 2008 07:53 PM
klwdesigns View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Front turn signal bulbs 11 Sample 3247 Re: Front turn signal ...
 Sat Mar 15, 2008 02:25 AM
Sample View latest post
