Visitors: 134
Total: 134
06: My Account
68: Event Calendar
69: Pictures
76: Event Calendar
96: Home
98: Event Calendar
109: Home
111: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wheel studs
Wheel studs
bajatink
bajatink
Post Post subject: Wheel studs
Posted: Mon Jun 11, 2007 04:40 AM
Has anyone ever installed press in wheel studs in 4 bolt drums?
I haven't taken mine apart yet, but I was wondering if there is clearence inside the drum for the shoulders on the studs. I don't have a problem with the drilling of the hubs if they will work.
Thanks
Post Post subject: Re: Wheel studs
Posted: Tue Jun 12, 2007 02:35 AM
i,v used them on a rail before with out problems, maybe some one here can tell you more, ive heard of them stripping out in hub after awhile because the hubs on vw,s are kind of thin in that section ! somebody else might of had better luck, but i saw a guy getting tires at a store, and the guy putting on the tires stipped out one lug on the rear of bouth sides of his baja, and wasnt going to tell the owner, so being the fellow baja owner, i ratted him out!! so your call.
R.e.J.
R.e.J.
Posted: Tue Jun 12, 2007 07:55 PM
On one of the how to books I've read,they mention tack welding the stud onto the drum.
Posted: Wed Jun 13, 2007 12:54 AM
Here is a trick for you. Buy some quality bolts the same size as your lugs (either 12mm or 14mm depending on if its 4 lug or 5 lug). Screw them thru from the backside, grind the heads of the bolts down so they dont interfere with the brake hardware, tack weld them and your done.
Posted: Wed Jun 13, 2007 02:35 AM
leave it up to the zilla, he,ll tell ya how its done yea!!!!
R.e.J.
R.e.J.
Posted: Wed Jun 13, 2007 09:23 AM
Very good trick...
bajatink
bajatink
Posted: Thu Jun 14, 2007 05:46 AM
Thanks guys, the welder is what I was overlooking. I decided to weld the screw in studs to the drum for now(its free). If that fails I will drill out the studs for 14mm studs and go that way.
Thanks again
No new posts VW Volkswagen & Baja Bug General Discussion wheel offset question? 0 billyjoejimbob33 1836 wheel offset question?
 Mon Oct 22, 2012 12:31 AM
billyjoejimbob33 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 6222 Wheel travel stock vs....
 Tue Jan 31, 2012 01:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion 1960 vw baja surging/wheel hop problem
baja problems
24 hayduke 8182 Re: 1960 vw baja surgi...
 Wed Aug 04, 2010 02:40 AM
hayduke View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Need to borrow (2) 4-lug sotck wheel & tire set 2 fabinc 2311 Need to borrow (2) 4-l...
 Tue Jun 23, 2009 10:23 PM
danjones333 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wheeling in one wheel drive 6 brian10x 2838 Re: Wheeling in one wh...
 Wed Nov 26, 2008 10:03 AM
