Members: 1
Visitors: 173
Total: 174
 Members:
01: JWHracing > Home
11: Event Calendar
31: Event Calendar
34: Pictures
39: Home
53: Event Calendar
54: Event Calendar
61: Event Calendar
68: Event Calendar
74: Event Calendar
78: Event Calendar
79: Event Calendar
87: Event Calendar
94: Event Calendar
97: Event Calendar
103: Pictures
108: Event Calendar
109: Event Calendar
110: Event Calendar
118: Event Calendar
120: Event Calendar
137: Event Calendar
139: Event Calendar
141: Event Calendar
142: Event Calendar
154: Baja Forums
158: Event Calendar
159: Event Calendar
161: Event Calendar
162: Event Calendar
163: Event Calendar
164: Baja Forums
165: Event Calendar
168: Event Calendar
172: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Help installing door glass in a sedan?
bajatink
bajatink
Post Post subject: Help installing door glass in a sedan?
Posted: Thu May 31, 2007 04:55 AM
No! No! No! No!!!! I am trying to get my baja back together after paint and the door windows are giving me fits. I got all the parts in and the window doesn't want to move very easy.
Any help or tips would be greatly appreciated.
Thanks
Post Post subject: Re: Help installing door glass in a sedan?
Posted: Thu May 31, 2007 06:56 AM
Assuming all the parts are in correctly, you can take a bar of soap (you may have to trim it down with a knife or somehing to make it fit down inside) and rub it in the felts that the window travels in. This will help it move easier until it get broken in a little. Any kind of bar soap will work.
Posted: Thu May 31, 2007 07:55 AM
I leave everything loose and roll th window up then tighten it all down.
Posted: Thu May 31, 2007 04:23 PM
with the window down when you first go to roll it up does it tillt? if it does move the run chanel in at the bottom. the soap will help make it easier until it get broken in.
bajatink
bajatink
Posted: Sat Jun 02, 2007 07:02 AM
Thanks everyone, I'm getting closer.
No new posts Projects and Builds vw bug ABS door panels 0 Dalton 2548 vw bug ABS door panels
 Thu Jan 05, 2017 03:13 AM
No new posts Projects and Builds NEEDED! Door Handles 7 wideopenmotorsports 5711 NEEDED! Door Handles
 Sun Nov 22, 2015 06:27 AM
No new posts VW Volkswagen & Baja Bug General Discussion outside door handles 3 cperry2704 2672 Re: outside door handl...
 Tue Nov 09, 2010 07:55 PM
wtracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Advice on replacing glass 4 chickenpants 2114 Advice on replacing gl...
 Wed Nov 04, 2009 04:29 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion I finally finished my door panels! 6 JumpinBruceB 4403 Re: I finally finished...
 Sat Oct 10, 2009 01:56 AM
