Visitors: 221
Total: 221
15: Event Calendar
19: Event Calendar
29: Pictures
34: Pictures
35: Pictures
80: Pictures
90: Pictures
91: Drivers
135: My Account
154: Event Calendar
160: Pictures
162: Baja Forums
164: Baja Forums
166: Baja Forums
170: Baja Forums
171: Baja Forums
173: Baja Forums
178: Event Calendar
187: Baja Forums
188: Baja Forums
191: Baja Forums
192: Baja Forums
193: Baja Forums
194: Baja Forums
195: Baja Forums
196: Baja Forums
197: Baja Forums
198: Baja Forums
199: Baja Forums
201: Baja Forums
202: Baja Forums
203: Baja Forums
204: Baja Forums
205: Event Calendar
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: Baja Forums
210: AMAZON.com
211: Baja Forums
212: Pictures
213: AMAZON.com
214: AMAZON.com
217: Baja Forums
218: Event Calendar
219: Baja Forums
220: Baja Forums
221: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- brakes
brakes
ReefaCheefa
ReefaCheefa
Post Post subject: brakes
Posted: Thu May 17, 2007 09:19 PM
when i brake it takes a few pumpms for the shoes to evn reach the drum and even then it doesnt stop well. i bled my brakes. but it still wont brake. am i looking at a new master cylinder? or could i have other problems?
Chanz
Billy
Billy
Post Post subject: Re: brakes
Posted: Thu May 17, 2007 09:55 PM
try adjusting the stars so that the pads have less distance to travel to brake. Especially if your lil tihngs to keep em in place came out, they may have gotten out of adjustment. New masters arent ungodly expensive so if that's the route you take, its no problem. Try adjusting the starts and really making sure you got all the air outta the lines first though.
ReefaCheefa
ReefaCheefa
Posted: Thu May 17, 2007 10:15 PM
thanks. yeah im gonna try and replace my mater cyl. cuz i bled my brakes yesterday but the pedal seems to compress all the way to the floor anyways. so i will se how it goe and let you know thanks again for the advice!
Chanz
sickbaja68
sickbaja68
Posted: Thu May 17, 2007 10:20 PM
I'd check the pads to see if they're worn down. If not, adjust them and go around and bleed them again and again. Might even be the main line inside the car itself. I ran into the same problem with mine. And ended up replacing the main brake line. Its a common thing for that line to go bad. Then, I finally replaced my master cylinder. Hope this helps out.
ReefaCheefa
ReefaCheefa
Posted: Thu May 17, 2007 10:44 PM
ill try it out thanks for the info. yeah i just replaced the shoes so i know there good. now ive heard from different people to bleed right rear first and then i hear to bleed right front. which do i do for a 73 super beetle? i also dont see a right rear bleeder valve. could it be plugged? if so ho do i bleed it with no valve?
Chanz
sickbaja68
sickbaja68
Posted: Thu May 17, 2007 10:57 PM
Doesn't matter for bleeding any year they're all the same. Start at the right rear, left rear, right front, left front. Follow that path and you'll be fine. Maybe the adjuster has a plug over it. The adjuster is at the bottom that you use a flathead screwdriver to adjust the pads. The bleeder valve is at the top you can't miss it. If its not there, then go buy it and install it, bleeder valve that is. But, take a look inside first too make sure nothing else is missing. You know it might or could be your wheel cylinders. I also, had to replace mine cause the guy before me put on the wrong year wheel clyinders and I didn't want to chance it cause it is your brakes. Might want to get a good repair manual and read up on it. Good luck.
Posted: Fri May 18, 2007 01:27 AM
You need to adjust your brakes, Yo have to djuster holes on each brake backing plate. both holes look like long ovals. VW brakes are manul adjust and you need to do this about ever 3 to 6 months. Do this first!!!!! You can not bleed your brakes with the brakes not adjusted.
Brakes Close up with parts, click me
How to work on VW Bug Brakes, Click Me, This is a must read.
sickbaja68
sickbaja68
Posted: Fri May 18, 2007 05:13 PM
Thanx, for the pics. That's what I was trying to let ReefaCheefa him or her know. Now the pics will clarify. He should still adjust the pads and then bleed them again and again. Nice thing is, is that there isn't that much to a vw brake system. However, it sure can add up in price quickly as I found out myself.
ReefaCheefa
ReefaCheefa
Posted: Fri May 18, 2007 05:27 PM
my uncle told me to adjust the brakes by backing up and braking repetitivly to kinda self adjust. i trust him and he is a good mechanic but i dont think he knows much about bugs, nor do i but i was just wondering if that will work? but thank you a lot for tyhe diagram and pic visual is a lot better
Chanz
sickbaja68
sickbaja68
Posted: Fri May 18, 2007 05:32 PM
LOL. Good one uncle. Please dude, follow all the advice we have given you at this point and you will have done it the right way. Good enough said.
T_Town_Baja
T_Town_Baja
Posted: Fri May 18, 2007 09:29 PM
On a lot of newer cars this trick will work by using the E-brake. On the VW, it is not equiped to do so.
Also, to clarify the picture, they are brake shoes for drums. You tend to get a giggle from the parts guys when ordering "pads" for drum brakes.
Blaine
Posted: Sat May 19, 2007 09:14 AM
You need to get under the car and get dirty. This will not work on a VW and most older cars. Self adjusting brakes started to show up in the 60's on most cars. VW's never got them so you need to adjust them your self. about once every 3 to 6 months.
ReefaCheefa
ReefaCheefa
Posted: Sun May 20, 2007 04:58 AM
ok heres the deal i changed my master cylinder everything went fine now i go to bleed my right rear tire and the valve broke inside the wheel cylinder. what are my options? do i have to buy a new wheel cyl.? or how do i remove the broken peice inside it to replace it? i was kinda tryin to hurry cuz it was getting dark and unfortunatly i dont have a nice garage. so i fuged up and rushed and broke a valve. Mad
Chanz
Posted: Sun May 20, 2007 08:20 PM
You have two choices replace the cylinder or use an easy out on the bleader valve and try to match it up with a new one. It might be easier to just replace the cylinder.
sickbaja68
sickbaja68
Posted: Mon May 21, 2007 11:11 PM
Good tip, replace the wheel cylinder and start over bleeding the brakes. I did mine yesterday and we had to bleed them a couple of times before we started to get pedal pressure. Don't pump the pedal so hard either, like slamming it and pushing on it hard. Take your time. Pump a few times then bleed and repeat 2 or 3 times per wheel as you go around. But, keep in mind that the brake pedal will feel alittle spongey until the pads or shoes wear in as you drive the baja around. If it don't feel right, then rebleed the system till it does. Also, be patient. This is something we all have to endure with owning a VW.
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3335 Re: bj front disk brak...
 Thu Dec 13, 2012 02:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion front brakes on a sandrail 2 Thuff 2277 Re: front brakes on a ...
 Thu Jan 29, 2009 02:11 AM
No new posts VW Volkswagen & Baja Bug General Discussion Emergency Brakes With 3x3 Arms 0 57baja 1972 Emergency Brakes With ...
 Sat Sep 20, 2008 07:48 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion brakes??? 0 KrazyKarl 1230 brakes???
 Thu Jun 12, 2008 05:50 AM
KrazyKarl View latest post
No new posts VW Volkswagen & Baja Bug General Discussion new brakes,not satisfied 1 todd 1641 Re: new brakes,not sat...
 Sun Sep 02, 2007 05:39 PM
