Visitors: 169
Total: 169
09: Home
10: My Account
13: Home
41: Home
45: Pictures
85: My Account
87: Event Calendar
105: Pictures
125: My Account
127: Garage
136: Home
139: Home
140: Home
158: Baja Forums
164: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Just picked up a '63 Baja...need advice
custom1106
custom1106
Post Post subject: Just picked up a '63 Baja...need advice
Posted: Wed May 16, 2007 06:44 AM
Just picked up a '63 Baja...and need some advice. I have messed with Ford and GM Trucks for years, so I'm new to the VW Crowd.
There are a couple of problem areas...
Steering is really tough...like something is binding. The guy that I bought it from gave me a new steering damper with it. Could this really be the problem? I'm a big guy and I still have to put all my weight into steering the car.
The steering also wanders bad...like unsafe bad, road walks alot as well as a bunch of play. (kingpin front end)
Where do I start? Are these common problems? I just don't want to start in the wrong place.
Thanks for all the info.
Custom
Post Post subject: Re: Just picked up a '63 Baja...need advice
Posted: Wed May 16, 2007 07:09 AM
rebuild the king pins
www.chircoestore.com/c...1f7ab599bc
check the steering box and coupler.
got book?
R.e.J.
R.e.J.
Posted: Wed May 16, 2007 07:25 PM
got book?
Allways wanted to try that also.
azhunter
azhunter
Posted: Thu May 17, 2007 01:33 AM
Check the steering box lash. I think its set up like a ford or gm box, box centered. Sounds like to me he bajafun is on the money though. You could disconnect one thing at a time and pinpoint it to the problem. I think to rebuild a king pin front end, you need to ream the new bushings after driving them in.
Posted: Thu May 17, 2007 01:58 AM
thinkin bout it, Mykul had a similar prob. he loosened the steering coupler/ joint at the steering box. it was all better!
Posted: Fri May 18, 2007 03:06 AM
Ya, my shaft was too tight!! Shocked
When I put my new streering box on I put the shaft too low, all I did was loosen the coupler at the grear box and move it up about a quarter of an inch.
vwbill
vwbill
Posted: Fri May 18, 2007 04:46 AM
Also check the link pins. Thes hold the king pins to the trailing arms, have a quarter turn of adjustment and are held in with a pinch bolt on the trailing arm. If loose you will have play side to side like worn ball joint feeling.
William
custom1106
custom1106
Posted: Mon May 21, 2007 02:52 AM
Threw a new steering box and rag joint on it and everythings working fine. Greased the hell out of everything on the car, rides nice, and doesn't road walk. The old box made grinding noises when I turned the input shaft with some pliers. Thanks for the info...much appreciated!
Custom
1963 Baja Beetle
1972 Std Beetle
5 Admin_AzBaja 6842 Baja Bugs on Wiki need...
1568 mufasavnvmc 1000956 Re: what did you do to...
285 MusicManiac 241769 Re: Baja sightings
0 Northmountainauto 1554 Shop Baja
