Visitors: 84
Total: 84
12: Event Calendar
32: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- NO Spark????
NO Spark????
MontanaBaja
MontanaBaja
Post Post subject: NO Spark????
Posted: Tue May 15, 2007 02:38 AM
I own a 1968 vw baja bug and just reasantly it quit, now i have gone over it a hundred times and know it is not gitting spark to the plugs. I have replaced the points, the condensor, the coil, the spark plug wires, the spark plugs themselvs, and it still gits no spark. so the only thing i havnt done is replace the distributer. it is a 007 boch. Oh yeah i also replaced the cap and rotor. soo if you have any ideas please leav a comment.
thanks
P.S.
i tested the cables with a timing light so i know there is no spark.
Post Post subject: Re: NO Spark????
Posted: Tue May 15, 2007 03:10 AM
Is there power to the coil?
MontanaBaja
MontanaBaja
Posted: Tue May 15, 2007 03:27 AM
yes, we also checked that with the timing light. i can not figure out what would be the problem.
Posted: Tue May 15, 2007 04:17 AM
How do you check that with a timing light? If the timing light flashes you have spark.
azhunter
azhunter
Posted: Tue May 15, 2007 06:09 AM
Is the coil wired correctly?
azhunter
azhunter
Posted: Tue May 15, 2007 06:10 AM
The neg side should flash while cranking. Check it with a "test light" not a timing light
coreyvdg
coreyvdg
Posted: Tue May 15, 2007 09:34 AM
pull the plug wires and stick a screw driver in them and touch it to the frame somehere and try to crank it...thats how i check for spark Wink
next i would touch the wire from ignition to the coil by tapping it against the frame somewhere when the ignition is on...
www.nmsandrails.com
View user's profile Visit poster's website AIM Address MSN Messenger
Posted: Tue May 15, 2007 04:41 PM
A test light would be less eventful when testing the lead to the coil. A known good spark plug in the end of the cable is an easy way to check the ignition at the spark plug end. Like Mykul stated, if the timing light is flashing, you have spark where the pickup is on the wire.
azhunter
azhunter
Posted: Wed May 16, 2007 12:55 AM
Good luck
R.e.J.
R.e.J.
Posted: Wed May 16, 2007 07:22 PM
That's what I was wondering,a test light to show if power comes on when the key is in the run position,or make one from an old 1156 bulb(Crap, that's the single filitment right?).
Also could the points have came loose and are closed?
azhunter
azhunter
Posted: Thu May 17, 2007 01:29 AM
Check the pos. side with the test light, it should be keyed power on. the neg. side of the coil should flash when cranking. The flashing indicates if the points are opening and closing thus discharging the condensor. Go to your local lawnmower shop and get a spark tester made for briggs (air cooled) engines. The spark should jump a 5kv gap easily. That will tell you the quality of spark. An electronic ingition setup will,should, jump a 10-20kv gap. OUCH!
sickbaja68
sickbaja68
Posted: Thu May 17, 2007 03:22 AM
Sounds like it might even be a bad fuse. Or wiring or the coil did go bad, but not likely.
azhunter
azhunter
Posted: Thu May 17, 2007 05:25 AM
Bad coil is possible. There is an ohm spec for the primary and secondary windings. I don't know what they are off the top of my head though. I think they vary per manufacturer.
MontanaBaja
MontanaBaja
Posted: Thu May 17, 2007 11:48 PM
thanks so much every one for the posts. i have checked the coil with a timing light, have even had the guy i bought it from come over to help me. He is a vw freak and was still stumped. I dont know what im going to do. ill probly just have a vw mechanic that only works on older bugs come over to fix it. he told me he would do it for cheap beacaus the guy i bought it from is a close friend. thanks again for the tips, and ideas.
Posted: Thu May 17, 2007 11:52 PM
Let us know what he finds, and how he found it. We can always learn something new.
No new posts VW Volkswagen & Baja Bug General Discussion Spark Plug Wires 6 bajatink 2922 Re: Spark Plug Wires
 Tue Mar 20, 2007 05:06 AM
bajatink View latest post
No new posts VW Volkswagen & Baja Bug General Discussion spark plug??? 0 sig1 1007 spark plug???
 Tue Jan 16, 2007 10:06 PM
sig1 View latest post
