Latest: jor_dang420
Overall: 3597
Visitors: 92
Total: 92
13: Pictures
17: Pictures
21: Event Calendar
44: My Account
53: Event Calendar
55: Event Calendar
76: Event Calendar
80: My Account
87: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- engine choice to make
soopercoop
soopercoop
Post Post subject: engine choice to make
Posted: Fri May 11, 2007 10:11 PM
Hey guys,
I just picked up a 74 bus for the tranny for my rail. It has
IRS setup already and was thinking about using the 2.0l bus
engine. It had a fuel injection fire but I quess you can con-
vert to carb. Also heard parts are expensive if I need to
replace any. Now the real question, I can buy a buddy's
84 toyota truck complete with 22re for cheap! It was
supposed to have a top end rebuild just a couple years ago.
So adapter plate, radiator, wiring, computer misc. Or go
through bus engine with no adapter plate just rebuild for carb?
How much h.p. from a bus engine and are they alright for
sand dunes?
Thanks,
Post Post subject: Re: engine choice to make
Posted: Sat May 12, 2007 02:17 AM
thats a tough call too make, you'll have to sit a think about it. first with the toyota engine the price of a conversion plate is 420 bucks, and you dont have to run the computer unless you want to. you can also use the stock rad. until you have enough money to buy an aluminum one, also you will have to upgrade your torsions for the added weigh and weld on motor mounts. if that doesn't scare you off i say go for it...b.t.w. thats what im about to do in my rail (22r) as soon as i get it back from the machine shop... Wink
soopercoop
soopercoop
Posted: Sat May 12, 2007 02:36 PM
What do you mean by upgrading my torsion, just turn them
up a couple splines? Also I'll probably run 2x3 trailers to
use stock bus axles, will this harm or help the torsion issue.
Also, do you have a wiring diagram your using? and what
do I do to not use the computer?(22re) The local toyota dealers
can't help with a diagram. Welding mounts is'nt a problem.
Do you need to use a fan with your radiator?
Any pictures or more advise is greatly appreciated.
Thanks,
Coop
Posted: Sat May 12, 2007 05:25 PM
if you running stock torsions now you will have to install bigger ones, im going to use 28mm. no wiring diagram, i have a very knowledgeable neighbor arcoss the street that has been wrenching for 30 years. you will need a fan for the radiator also.
soopercoop
soopercoop
Posted: Sun May 13, 2007 04:17 AM
Thanks for all your input. Hope your rail kicks a_ _! Very Happy
Coop
Posted: Sun May 13, 2007 10:08 AM
great looking car, is that u in the background? Its a ford, how much lower does this engine sit compared to a vw?
Posted: Sun May 13, 2007 06:15 PM
this is azbaja own baja with a 2.3 ford...its not so much about h.p. but about torque....
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 1571 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 2395 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 2573 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 2586 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 5250 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
