Latest: strike77
Overall: 3575
Visitors: 86
Total: 86
08: Event Calendar
22: Event Calendar
25: Home
27: Home
28: Home
40: Event Calendar
45: Event Calendar
73: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- azbaja question
azbaja question
Post Post subject: azbaja question
Posted: Wed May 09, 2007 05:33 AM
hey what size rad and fan do you have on your baja ? thanks
Post Post subject: Re: azbaja question
Posted: Wed May 09, 2007 10:06 PM
I use a stock size pinto radiator and the black magic electric fan from summit or jegs
Posted: Thu May 10, 2007 02:43 AM
can you tell the exact size in inches, fan and radiator...thanks again
azhunter
azhunter
Posted: Thu May 10, 2007 06:38 AM
Check this out.....
cgi.ebay.com/ebaymotor...0089243745
Posted: Fri May 11, 2007 01:33 AM
yeah, does that seem to be alittle big ? i've been looking on evilbay and it would seem that somewhere around 150 to 175 for a radiator, aluminum of course... im going to have to figure out what size would be best and max cooling too...thanks azhunter......
Posted: Fri May 11, 2007 01:41 AM
18" wide x 20" tall bigger is better. If you plan on long drives you will need to get a bigger radaitor I wish I had done that. Long trips over 2500-3000rpm about 55 to 65mph in my baja build up alot of heat. 225 or so
Posted: Fri May 11, 2007 02:36 AM
are you running a thermostat, and if you are what temp is it ? also have you ever used waterwetter, its maded by REDLINE and it does work, iv'e used in my suburban... Wink
cgi.ebay.com/ebaymotor...7048QQrdZ1
Posted: Fri May 11, 2007 03:38 AM
I think I have 195 in it now. But water cooleds do not like to run at 3000rpm for a long time. Yes I have heard of the red line stuff just never tried it. We had gimicks like that when I was growing up. But that was over 20 years ago and the stuff did not work.
29 AzBaja 29120 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
32 AzBaja 31447 Get the www.AzBaja.com...
 Fri Feb 03, 2012 11:36 PM
1966baja View latest post
No new posts Events and Get Togethers World Wide 2018 AZBaja 9th Annual Play Day, Date.... 0 Dirtjunkie 321 2018 AZBaja 9th Annual...
 Wed May 23, 2018 03:59 PM
No new posts Events and Get Togethers World Wide 8th Annual AzBaja Playday 2017
October 6,7,8 2017
19 Dirtjunkie 4286 Re: 8th Annual AzBaja ...
 Tue Oct 10, 2017 06:49 PM
No new posts Events and Get Togethers World Wide AzBaja Playday 2017?
Move Location?
18 Dirtjunkie 4214 AzBaja Playday 2017?
 Fri Sep 29, 2017 10:34 PM
Rigger View latest post
