Visitors: 97
Total: 97
29: My Account
36: Home
40: Home
41: Home
52: Home
77: Home
86: Home
90: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Motor running!! (finally)
Post Post subject: Re: Motor running!! (finally)
Posted: Fri May 04, 2007 01:28 AM
BugZyla.com wrote:
Also if you have an issue with header/exhaust gaskets leaking, throw away the gasket and just use Ultra Copper silicone. I have used it in place of gaskets for years, and once the bolts are tight, you dont have to worry about the paper/metal collapsing over time and allowing the nuts/bolts to loosen and creating exhaust leaks.
www.permatex.com/produ..._Maker.htm
Jeeze, looks like a freakin permatex comercial in here. Mr. Green
daryll, would you recommend that stuff for a chevy 350 header gasket ?
tsutt
tsutt
Posted: Fri May 04, 2007 02:31 AM
Yes, And it works for the egr valve's also. course i'm not bugzzy. Todd
Jordynarz
Jordynarz
Posted: Fri May 04, 2007 03:16 AM
I started it up today and It smoked really really bad! I have only run the motor a little over 5 minutes total. But It still smokes. Any Ideas?
azhunter
azhunter
Posted: Fri May 04, 2007 05:13 AM
I hear they make patches you can put on the tires to help curb the urge to smoke. Cool
Does it smoke at idle, accel,decel or all the time.
Posted: Fri May 04, 2007 05:29 AM
if its sat for a good while, the rings may be unseated from non use.
run it gingerly a couple times allowing to warm up slowly. the more it runs, the more the rings will re-seat and the smoke should clear.
otherwise there is an oil leak into the cylinder somewhere...if its white
if its black then you have a carb issue ...too much fuel.....
Jordynarz
Jordynarz
Posted: Fri May 04, 2007 06:22 AM
Well it smoke white a lot! But I had the cylinders honed and I had to get 2 new ones. 2 of the old ones were pitted. But we also put oil in the cylinders. Also we need to time it. At first it would not start then we turned the distributor and it ran really crappy. But it still runs crappy. We are going to borrow a timing gun sometime to time it. But hopefully The rings will seat soon.
Jordynarz
Jordynarz
Posted: Sat May 05, 2007 04:00 AM
hi
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 5058 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
No new posts Projects and Builds class 5 baja bug needs motor... 0 Azbugracing1214 2978 class 5 baja bug needs...
 Tue Jun 09, 2015 12:51 AM
No new posts New Members Running the wash 3 Mtp456 3094 Running the wash
 Mon Jan 26, 2015 04:12 AM
No new posts Projects and Builds FINALLY 5 bugzapper 3984 FINALLY
 Fri Jul 27, 2012 04:08 AM
No new posts Projects and Builds Where to buy ecotec 2.2 motor mounts? 1 cycleguy1979 2548 Where to buy ecotec 2....
 Sat Jun 30, 2012 01:41 AM
