Visitors: 134
Total: 134
64: Event Calendar
74: Pictures
77: Event Calendar
88: Pictures
93: Garage
103: Pictures
117: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cv broke
cv broke
milleraj119
milleraj119
Post Post subject: cv broke
Posted: Thu May 03, 2007 10:38 PM
i was drivin down the road and randomly my bug felt like it poped out of gear it dident and i came to a complete stop and i was still in gear and it dident die i went back and looked at the trans and the right side was only spinning but the cv wasent turning the wheel its irs buy the way. anyone have any ideas
Post Post subject: Re: cv broke
Posted: Thu May 03, 2007 11:05 PM
Which CV? The inside one by the trans, or the outer CV by the wheel? Could be a busted axle, couldn't it?
milleraj119
milleraj119
Posted: Fri May 04, 2007 04:18 AM
found the prob the drum splines were shot and went and bot a new drub and its totally differnt the old one has studs coming out and is smaller the new one has thareaded holes so i have no idea what tipe of drums are on my bug f...in sucks
azhunter
azhunter
Posted: Fri May 04, 2007 05:16 AM
You need to swap the studs out. They screw in. If they're welded in, buy another set. If you return the new drum, take the old one with you.
milleraj119
milleraj119
Posted: Fri May 04, 2007 03:46 PM
the studs are pressed in and i cant find the right threaded rod at the hardware store the people that work there couldent even find one and its size 14 pretty big and i just found out the bug has bus brakes all around so i need to take it back and get a bus drum
Posted: Fri May 04, 2007 04:15 PM
If you need a stud kit, the 14mm ones are here
www.chircoestore.com/c...aa66d30e7c
and the 12mm ones are here
If you have a 5 lug 14mm you will have to order 2 sets off the 4 lug 14mm to get enough, but at least you will have spares.
Posted: Fri May 04, 2007 04:25 PM
Yes, take the old one with you!!!!
No new posts Events and Get Togethers World Wide TOO BROKE FOR STURGIS - Ride 2 Preston 2358 Re: TOO BROKE FOR STUR...
 Mon Jul 21, 2008 06:39 PM
Preston View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 3rd clutch cable broke in less then 6 months 6 milleraj119 2850 Re: 3rd clutch cable b...
 Thu May 17, 2007 10:42 PM
sickbaja68 View latest post
