Visitors: 82
Total: 82
07: Event Calendar
31: Event Calendar
39: Home
61: Event Calendar
77: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Motor running!! (finally)
Jordynarz
Jordynarz
Post Post subject: Motor running!! (finally)
Posted: Thu May 03, 2007 05:57 AM
I finally got my motor finished and in. It's pretty cool. But the #4 cylinder leaks oil. I used silicone to seal it. But I remember it leak in the same spot before I took it out. So I don't know. My dad ordered floor pans a air cleaners. It still need body work, but oh well. for now I'll tune the motor and carbs.
Post Post subject: Re: Motor running!! (finally)
Posted: Thu May 03, 2007 06:01 AM
umm...yea...silicone is my game !!!!
no really, oil will eat silicone for lunch!
silicone is an EMERGENCY fix on any engine.
wheres it leakin from?
if its the heads, torque em down.
valve covers, find some aircraft gasket maker and use it on the valve cover side (small amount) with a new cork gasket..unless you have those fangled high tech valve covers thta have to have rubber...stockers use CORK only.
Jordynarz
Jordynarz
Posted: Thu May 03, 2007 06:05 AM
Well there is no gasket that came that would fit my cylinders. I have an 1835 cc and the gasket would not fit. So the guy at this shop said he uses silicone. So I used the high heat red stuff. It leaks from the cylinder at the block.
Posted: Thu May 03, 2007 06:07 AM
post a pic please.
he sounds like hes lazy or just high!!!
an 1835 is just a 1600 warmed over. stock covers and such even.
Jordynarz
Jordynarz
Posted: Thu May 03, 2007 06:09 AM
Well I tried to put the paper gasket on and it did not fit. It was the same size as it around it wouldn't go over the cylinder.
Jordynarz
Jordynarz
Posted: Thu May 03, 2007 06:16 AM
I will take a pic tomorrow after school and put it on here. But what s weird is that it leaked in the same area before I took the motor out. Do you think I can try to put more silicone around the area?
you talkin cyl or valve cover gasket???
call Chirco fri or sat and ask
1-800-955-9795
Jordynarz
Jordynarz
Posted: Thu May 03, 2007 06:17 AM
The cylinder. It leaks by the case on the #4.
Posted: Thu May 03, 2007 06:18 AM
see above ^ and call chirco!!!
my mistake previously, understood it to be valve covers Embarassed
Jordynarz
Jordynarz
Posted: Thu May 03, 2007 06:24 AM
Ok. So I have no Idea why it leaks? Other than it has a silicone for a gasket. Maybe case problem.
Posted: Thu May 03, 2007 06:25 AM
call Chirco and ask..its free!
Jordynarz
Jordynarz
Posted: Thu May 03, 2007 06:31 AM
Ok.
coreyvdg
coreyvdg
Posted: Thu May 03, 2007 06:52 AM
I had the same problem when i built my 1835. The gaskets that go between the case and the jugs need to be bigger obviously, but the gasket pack came with 1600 gaskets. I ended up tearing the gasket on the top a little bit and just used the 1600. I had a small leak on one cylinder as well, nothing that i worried about. I added oil every month or so...
www.nmsandrails.com
View user's profile Visit poster's website AIM Address MSN Messenger
Posted: Thu May 03, 2007 04:36 PM
I use the Permatex Super 300 gasket sealer www.permatex.com/produ...ealant.htm on EVERYTHING. In cases where you have imperfections and leaks, you can use the ultra grey silicone www.permatex.com/produ..._Maker.htm . Oil does not effect silicone, but I recomend using it sparingly. I have seen motors with so much silicone on them, that the excess drops inside the motor and clogs up the oil pickup screen.
Posted: Thu May 03, 2007 04:42 PM
Also if you have an issue with header/exhaust gaskets leaking, throw away the gasket and just use Ultra Copper silicone. I have used it in place of gaskets for years, and once the bolts are tight, you dont have to worry about the paper/metal collapsing over time and allowing the nuts/bolts to loosen and creating exhaust leaks.
Jeeze, looks like a freakin permatex comercial in here. Mr. Green
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 4162 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
No new posts Projects and Builds class 5 baja bug needs motor... 0 Azbugracing1214 2652 class 5 baja bug needs...
 Tue Jun 09, 2015 12:51 AM
No new posts New Members Running the wash 3 Mtp456 2736 Running the wash
 Mon Jan 26, 2015 04:12 AM
No new posts Projects and Builds FINALLY 5 bugzapper 3742 FINALLY
 Fri Jul 27, 2012 04:08 AM
No new posts Projects and Builds Where to buy ecotec 2.2 motor mounts? 1 cycleguy1979 2393 Where to buy ecotec 2....
 Sat Jun 30, 2012 01:41 AM
