Visitors: 113
Total: 113
59: Event Calendar
65: My Account
82: Event Calendar
102: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- easy shift rod question....
r8rfan66
r8rfan66
Post Post subject: easy shift rod question....
Posted: Thu May 03, 2007 03:13 AM
New to the VW world and am havin a great time gettin my 66 road worthy. (I may have to hawk the hou$e pretty soon).
I have a 66 bug (s/a trans) and was wondering if the shift rod is designed to have an "angle" bent in the center, or do I need to replace a bent shift rod?? Thanks again as always!
Post Post subject: Re: easy shift rod question....
Posted: Thu May 03, 2007 05:10 AM
THE SHIFT ROD THRU THE TUNNEL (NO BENDS) SHIFTER IT SELF SLIGHT BEND (MAYBE)
r8rfan66
r8rfan66
Posted: Thu May 03, 2007 05:15 AM
Thanks for the info!
Posted: Thu May 03, 2007 05:23 AM
I've heard that some do have bends. Does it work? If so why would you replace it?
r8rfan66
r8rfan66
Posted: Thu May 03, 2007 06:27 AM
I drove this car once since I bought it, and not sure if it was working or not. I know the bushing was gone, and I couldn't get 1st gear. I thought it was the trans so I bought a rebuilt one and installed it, and guess what? Same problem. I've heard of angled shift rods before, but just wanted to be sure before I attemp to re-install.
Posted: Thu May 03, 2007 07:10 AM
may just need to adjust the shift cable on the trans.
Posted: Thu May 03, 2007 04:28 PM
I shift rod DOES have a slight bund to it. With the hole for the shifter pointing up, it will have a slight bend towards the bottom.
r8rfan66
r8rfan66
Posted: Sat May 05, 2007 06:39 AM
got it in with a new bushing, and got gears! I think I may need to adjust the stop plate, cuz even though I have gears, they don't glide in. The rod did have a slight bend as you descibed. Is this normal on a newly re-built trans? (possibly?)
Thanks guys!
fatalifeaten
fatalifeaten
Posted: Mon Aug 06, 2007 06:52 PM
I've got a rebuilt Rancho Swinger in my '66, and I had problems finding gears properly. Turned out that the t-handle shifter I had was a POS, so I went back the the original one and a short throw kit. Problem solved. I still have a little problem downshifting from third to second, but it's something I will be able to dial out by adjusting the shifter slightly. I"m just lazy Smile
--Harlan Ellison
Posted: Mon Aug 06, 2007 07:33 PM
I have the Scat T-Handle shifter inmy car and the shifter rocks!!! it's over $75 but it's worth it. I had the empi thing in my car before and it sucks... a $75 shifter is good shifting, a $20 shifter well it's a $20 shifter and you will hate it.
Posted: Mon Aug 06, 2007 07:37 PM
O' no the swingers are out.. Twisted Evil
fatalifeaten
fatalifeaten
'Zactly. I had the old Hurst in my '67. That was the coolest shifter ever! I'm going to try and find another one used, but if I can't I'll probably save my pennies for one of the CSP ones.
--Harlan Ellison
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 8088 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Question about local vendors in the Phoenix Valley areas 2 Salvo 2728 Question about local v...
 Fri Sep 20, 2013 07:37 AM
Sweetjumps View latest post
No new posts VW Volkswagen & Baja Bug General Discussion homade baja fenders question 9 vtbaja 5525 Re: homade baja fender...
 Mon Sep 16, 2013 06:23 PM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 3541 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
No new posts VW Volkswagen & Baja Bug General Discussion super baja question 9 vtbaja 4486 super baja question
 Thu Aug 29, 2013 11:07 PM
