Visitors: 135
Total: 135
53: Home
76: Event Calendar
98: Home
112: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Ideal year for baja bug.
lrishm4n
lrishm4n
Post Post subject: Ideal year for baja bug.
Posted: Wed May 02, 2007 07:09 AM
This summer I have found a job that will fund my baja undertaking. I have been planning to purchase a VW bug to turn into a baja but I am uncertain as to which year to purchase. Is there any drawbacks to any of the many years of production? My grandfather told me of ball joints on the wheels that are not ideal. But is there any one year that is ideal for this project?
With Respect.
-Greg
Post Post subject: Re: Ideal year for baja bug.
Posted: Wed May 02, 2007 07:17 AM
The favored front end is called a linkpin front end (original equipment on models prior to ball-joint front end, which was introduced in 67 or 68?). Favored rear suspension is the IRS, which (of course) didn't begin production until 67 or 68. Basically, NO production models had the better front end AND the better rear end, so you've got to change one end or the other if you want linkpin AND IRS.
Makes the decision easier, right? =)
theres no right answer. just try to avoid super beetles. they are a pain to convert.
lrishm4n
lrishm4n
Posted: Wed May 02, 2007 07:43 AM
Then what about the inverse of that? What is the easiest year to convert?
Posted: Wed May 02, 2007 07:48 AM
all depends on preferences.
do you want IRS? are ya comfortable with swing axle?
then theres king pin front end or ball joint front end...choice is up to you!
Posted: Wed May 02, 2007 08:49 AM
67 has both a ball joint front and a swingaxle rear.
Posted: Wed May 02, 2007 04:32 PM
As does a '66. Depending on how hard you are going to drive, most people would recommend getting one with IRS. "69 and newer. You can do a lot of off road with the ball joint front end and convert it if/when it breaks. Driving a lifted swingaxle off road is a little more precarious.
Hope that helps. Cool
sandshark
sandshark
Posted: Wed May 02, 2007 08:24 PM
Is it necessary to change the pan head to convert from a balljoint to king pin front? I'd like to go long travel eventually. I've also heard the king pin front will take more abuse. Anybody?
bajajon
bajajon
Posted: Wed May 02, 2007 08:31 PM
yes u have to change the head and it is stronger
dang, I broke it again
Posted: Wed May 02, 2007 09:56 PM
THE IDEAL YEAR FOR A BAJA IS THE ONE YOU OWN!! HUH !!
Posted: Thu May 03, 2007 02:17 AM
THE HARD CORE OFF ROAD (BAJA) GUYS USE A KING PIN FRONT WITH AN IRS REAR. YOU HAVE TO CONVERT FROM ONE TO THE OTHER DEPENDING ON THE YEAR OF THE PAN.
with that said, go find a decent specimen of an aircooled classic. take some pics. post em on this site.
then go and make a baja and have fun!!!
Arizonateacher
Arizonateacher
Posted: Thu May 03, 2007 02:24 AM
Pick up the one that has the most modifications done already. Since people who sell them do not realize all the money they spent they will not get back.
Posted: Thu May 03, 2007 05:16 AM
good advice.... Wink
Jordynarz
Jordynarz
Posted: Thu May 03, 2007 05:55 AM
Can you still lift the ball join front end?
Posted: Thu May 03, 2007 06:02 AM
you can turn and cut em easily enough.
5 Admin_AzBaja 6746 Baja Bugs on Wiki need...
1568 mufasavnvmc 998003 Re: what did you do to...
285 MusicManiac 240973 Re: Baja sightings
0 Northmountainauto 1511 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 4085 Baja hiding in Chandle...
