Latest: ecthemc
Overall: 3567
Visitors: 149
Total: 149
07: Event Calendar
16: Pictures
47: Event Calendar
61: Event Calendar
69: Pictures
82: Event Calendar
95: My Account
101: Home
114: Event Calendar
118: Event Calendar
143: Event Calendar
147: Pictures
1 2 3 ... 10 11 12 ... 103 104 105
Bahaw
Bahaw
Posted: Mon Apr 30, 2007 06:40 AM
Installed a progressive Weber, got brake lights working, adjusted the valves and installed new valve cover gaskets. Next will be install the turn signals, license plate light, horn & wipers. Oh yeah, if gotta come up with some door panels. thought about making them out of aluminum, but don't know yet.
Posted: Tue May 01, 2007 02:58 AM
Found out that I have to redo the sand seal!!! Daryll was right, I should have used JB weld, Crap why did I ever doubt the great and powerful Bugzyla!!! Embarassed No! No! No! No!!!!
Posted: Tue May 01, 2007 03:06 AM
jb weld? for what???????????????
Arizonateacher
Arizonateacher
Posted: Tue May 01, 2007 06:16 AM
I just got back from California with new seats, door panels, Light bar on top is installed. Lights on the front bumper., new carpet, slotted chrome wheels, new generator. Still its going be awhile, before I can take it out.
Posted: Tue May 01, 2007 06:32 AM
WOO WHOO!!! I KNOW WHERE IM GETTIN NEW PARTS TONIGHT Razz Laughing
Posted: Sun Aug 09, 2009 02:15 AM
Well I thought I'd revive this topic since it's been stagnent for quite some time.
Today I finished tearing the passenger sire rear torsion/spring plate down. As I stated in another post, I got a bit greedy when I indexed some time ago and she now rides like a freakin tank. Discovered the outter urethane grommit was in pieces. WTF???
Still have to tear down the drivers side but that'll wait until I get the new grommits from Chirco and finish the passenger side.
Re-torqued the heads. Found both front push rod tubes were seaping a little oil. Amazing they (heads) both had a few nuts that would start to turn at 10lbs on the torque wrench. Went through them all several times to be sure. Of course I re-adjusted the valves.
One other thing I've noticed is the fan belt alignment is off a bit. So I disassembled the altenator/fan housing to be sure the plate was installed correctly. With that and a little prying before I tightened down the sheet metal screws I was able to get it closer. Still not perfect but I "think" it should be ok.
That's pretty much all until I get my stuff from Chirco. I also have a Kennedy Stage-1 pressure plate and Kush Lock clutch disk coming. Discovered at the beach that the stock set up would not turn my 31" tires in the sand, at all. No! No! No! No!!!!
chickenpants
chickenpants
Posted: Sun Aug 09, 2009 03:12 AM
Pulled the new wiring harness out and put the wiring into expandable loom. Installed it all back in and started to secure it. Tomorrow I hope to finish securing the wiring in the groove in the heater channel and in the battery area and get the fuse block installed.
Stephen\r\nChandler, Az
Post Post subject: what do you do to your buggy/baja today
Posted: Wed Aug 12, 2009 10:02 AM
I did nothing with my Baja Sad But we did have a great party for my Little Girls Birthday Smile
baja17
baja17
Posted: Wed Aug 12, 2009 07:23 PM
goin to start sandin my car for paint it is goin to be painted neon green with ghost monster graphix painted on the rear quarter panel and room with gloss black, then i got these lights that are goin above the motor wheel wells they blink to beat of music and change color or u can have just one color, the motor has the chrome dress up kit so the lights will look good on the motor lol im and just got a new tube bender my cage inside is goin to be neon green to so the whole car will match...... more to come
olias-racing
olias-racing
Posted: Wed Aug 12, 2009 10:07 PM
will be working on placement and install of hood locks, then off to inspection
Posted: Sun Aug 16, 2009 12:51 AM
Got my Chirco shipment Friday. WOO-HOO!
Started to put the passenger side rear suspension together today; quickly realized that I ordered the wrong inner spring plate grommits. 1 7/8" instead of 2"
DAMN! I did measure only the outside of the spring plates.
Placed another order and begged Joe (via e-mail) to rush if possible.
I did install the Kennedy Stage-1 pressure plate and clutch disk. Converted the trans back over to the late style t/o bearing and carrier.
Posted: Sun Aug 16, 2009 05:41 AM
I DROVE mine for the first time in a month! Woo-hoo! Felt good too.
Brettucks
Brettucks
Posted: Sun Aug 16, 2009 05:44 PM
new wiper blades!! WOOHOO!!
Posted: Sun Aug 16, 2009 11:29 PM
ripped the headliner out cause it was failing out.
Posted: Mon Aug 17, 2009 03:01 AM
also painted the hole underneath and did some spot painting were it has been chipped from romping and what not
4 Admin_AzBaja 5060 Baja Bugs on Wiki need...
285 MusicManiac 205800 Re: Baja sightings
Off-road event
1 wideopenmotorsports 125 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3137 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion What is my Baja really worth? 1 Treeposter 857 What is my Baja really...
 Sat Jun 17, 2017 04:06 PM
