Visitors: 138
Total: 138
08: Event Calendar
27: Event Calendar
37: Pictures
38: Pictures
79: Event Calendar
81: Event Calendar
130: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cylinder 3 and 4+carb problems
milleraj119
milleraj119
Post Post subject: cylinder 3 and 4+carb problems
Posted: Sun Apr 22, 2007 01:25 AM
well i found outmy fan was cracked bad and so was the metal spacer so i replaced it and it now all works well after i put everyhting back together and went for a test drive i noticed something wasent right and i had lost about half my horse power so i looked around the engine to see what was goin on and i noticed that when i pressed on the gas on the left carb (dual 44 webers) that it was stallin and wasent firen the 3rd and 4th cylinder i felt the exuast tubes on that side and they were cold wich ment my spark plugs were bad so i got new ones and put them on number 3 and 4 cylinder and it ran good well i drove it down the road and it started loosin and jumpin and then died well i started it back up and it lost all the horse power agian and the left side pistons werent firin agian i tired mesin with the air and fual mixture and cleaned the carb and it still isent runnin right im really starten to get mad now i also checked the distributer wires and the all have spark runnin through them and the timing is set and both carbs are syncd iv been trying to find the problem all day and i no fore sure its the left side of the engine that is not workin right. thanks for the help
Post Post subject: Re: cylinder 3 and 4+carb problems
Posted: Sun Apr 22, 2007 02:24 AM
vacuum leak on the carb or intake manifold.
throw away the points (ok to the glove box) and install petronix electronic ignition pack.
make sure the plugs are in alll the way.
make sure exhaust is tight to jug.
milleraj119
milleraj119
Posted: Sun Apr 22, 2007 02:33 AM
ok well how would i find the vacume leak and how would i fix it can u by the electric egnition at a local auto parts store or order it offline
Posted: Sun Apr 22, 2007 03:34 AM
ju got carb spray cleaner?
start engine, lightly spray around the carb and manifold. listen for a pitch change in idle.
see here:
www.chircoestore.com/c...opic=686.0
www.chircoestore.com/c...pic=1537.0
www.chircoestore.com/c...board=11.0
pertronix from auto store or internet.
www.pertronix.com/new_...g_pg43.htm
azhunter
azhunter
Posted: Sun Apr 22, 2007 04:40 AM
Adjust the valves also. On the wires, just cuz they spark, doesn't mean it's good spark. Can't remember the spec. but there is an OHM spec. based on the length of wire. high resistance will cause a plug to foul wet. Three things can cause a plug to foul wet, lack or poor spark, way to much fuel, low compression. The problem is specific to that bank so focus on the carb. ign. or wires, valve adjustment od compression. The pertronics is worth the $$
milleraj119
milleraj119
Posted: Mon Apr 23, 2007 03:06 AM
well i looked for the vacume leek and cant find one and it seems werid to me that the engine ran fine until i changed the fan and altinator stand then went to fire it back up the left side wont fire the valvs were adjusted like 2 months ago with a full tune up and i can tell that the carb is givin gas becasue i can see it shoot into the butterfly then sucks it down also when the problem first accured i put in new spark plugs it ran 100% for like 10 miles then quit. the points all look good to im gonna go play with the plug wires and seee what happens
bajajon
bajajon
Posted: Mon Apr 23, 2007 03:39 AM
ive had a prob like that it was just a bad connection at the distributor i cleaned the holes in the cap out put in some dielectric grease and i was off i figured it out by twisting the spark plug wires on the cap.
dang, I broke it again
vwbill
vwbill
Posted: Mon Apr 23, 2007 03:45 AM
Double check the heat range of your plugs. I put bosch w7ac in my car one time and developed a miss while jump starting another car, never made it out of the parking lot. Saw this same situation on another car. Put the stock w8ac back in and it ran fine. The other car had a piece of hose debree sitting on top the float valve as well making the car run out of gas every few minutes.
William
Posted: Mon Apr 23, 2007 03:58 AM
Sounds to me like you either have a float sticking or there is some garbage in the carb letting the needle and seat stay open. Check the plugs you pulled out and see if they are gas fouled (wet with gas) if thats the case you need to pull the carb apart and clean it out. It typically happens when you take a carb off and disturb the sediment (garbage) at the bottom that builds up over time.
milleraj119
milleraj119
Posted: Mon Apr 23, 2007 08:22 AM
is the float located right were the gas hose connectes there 44 idfs
Posted: Mon Apr 23, 2007 03:55 PM
Yes it is.
milleraj119
milleraj119
Posted: Mon Apr 23, 2007 10:04 PM
took the hole carb off cleaned the shit out of it with carb cleaner drained all the gas out checked the float and the plugs they both seemed fine and the plugs are dry i have no clue whats goin on i even swaped the spark plug wires around and it still dident do nothing.
milleraj119
milleraj119
Posted: Tue Apr 24, 2007 06:58 AM
well i think i might of found the prob just gonna go and tune up the distributer and see what happens.
milleraj119
milleraj119
Posted: Sun Apr 29, 2007 03:29 AM
well im still havin problems i just tuned up the distributer and got new spark plug wires checked all my wiring and did i deep rebuild on my left carb took the hole thing apart and cleaned the shit out of it ther is compression in both cyilinders because i did a check on them and the coil is brand new so if anyone could please give me some advise it would really help before i blow the thing up.
ridinthedunes
ridinthedunes
Posted: Tue May 01, 2007 10:15 PM
I would kinda start from scratch.....check spark by actually pulling the plugs and using the one for each cylinder/wire to test each cylinder. then check for fuel....check idle jets again, just to make sure (5 minutes in a baja with 44idfs), check compression. You only need gas, spark and compression to make those cylinders fire, assuming timing. etc. is close enough that the other side is firing.
Did the old plugs look fouled (black)
What are your specs? (engine, cam, heads, jetting, etc)
will they fire if you rev it up (get off the idle jets and on the mains)?
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 9068 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Carb Intake Covers 3 k-man 2080 Re: Carb Intake Covers
 Tue Jan 10, 2012 11:46 PM
Gunpilot View latest post
No new posts Projects and Builds carb troubles
1968 carb troubles
11 vwbajabug1 4598 carb troubles
 Mon Nov 15, 2010 02:12 AM
vwbajabug1 View latest post
No new posts Projects and Builds wanting 34 pict-3 carb
i need a carb
0 vwbajabug1 1652 wanting 34 pict-3 carb
 Tue Nov 09, 2010 12:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion carb 9 luhrman645 4068 Re: carb
 Wed Aug 04, 2010 10:47 PM
