Visitors: 381
Total: 381
24: Event Calendar
38: Event Calendar
48: Event Calendar
52: Event Calendar
84: Event Calendar
109: Event Calendar
144: Event Calendar
164: Baja Forums
168: Baja Forums
170: Baja Forums
172: Baja Forums
173: Baja Forums
176: Baja Forums
178: Baja Forums
180: Baja Forums
189: Baja Forums
191: My Account
192: My Account
195: Baja Forums
197: Baja Forums
198: Baja Forums
201: Baja Forums
202: AMAZON.com
203: Baja Forums
204: My Account
205: Baja Forums
207: Baja Forums
208: AMAZON.com
209: AMAZON.com
210: My Account
211: Baja Forums
212: My Account
213: My Account
214: My Account
215: Baja Forums
216: Baja Forums
217: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Baja Forums
221: AMAZON.com
224: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: Baja Forums
229: AMAZON.com
230: AMAZON.com
231: Baja Forums
232: Baja Forums
233: AMAZON.com
234: Baja Forums
235: Baja Forums
236: AMAZON.com
237: AMAZON.com
238: Baja Forums
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: Baja Forums
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: Baja Forums
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: Baja Forums
256: Event Calendar
257: Baja Forums
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: Pictures
278: AMAZON.com
279: AMAZON.com
280: AMAZON.com
281: AMAZON.com
282: Baja Forums
283: AMAZON.com
284: AMAZON.com
285: AMAZON.com
286: Baja Forums
287: AMAZON.com
288: AMAZON.com
289: AMAZON.com
290: AMAZON.com
291: Baja Forums
292: AMAZON.com
293: AMAZON.com
294: Baja Forums
295: Baja Forums
296: AMAZON.com
297: Baja Forums
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: AMAZON.com
302: AMAZON.com
303: Baja Forums
304: AMAZON.com
305: Baja Forums
306: AMAZON.com
307: Baja Forums
308: AMAZON.com
309: AMAZON.com
310: AMAZON.com
311: AMAZON.com
312: AMAZON.com
313: AMAZON.com
314: AMAZON.com
315: Baja Forums
316: AMAZON.com
317: AMAZON.com
318: AMAZON.com
319: AMAZON.com
320: AMAZON.com
321: AMAZON.com
322: AMAZON.com
323: AMAZON.com
324: AMAZON.com
325: Baja Forums
326: AMAZON.com
327: AMAZON.com
328: Baja Forums
329: Baja Forums
330: AMAZON.com
331: Baja Forums
332: Baja Forums
333: AMAZON.com
334: AMAZON.com
335: Pictures
336: AMAZON.com
337: AMAZON.com
338: My Account
339: Baja Forums
340: Baja Forums
341: Event Calendar
342: AMAZON.com
343: Baja Forums
344: AMAZON.com
345: AMAZON.com
346: AMAZON.com
347: AMAZON.com
348: Baja Forums
349: Baja Forums
350: Baja Forums
351: AMAZON.com
352: AMAZON.com
353: AMAZON.com
354: AMAZON.com
355: AMAZON.com
356: AMAZON.com
357: AMAZON.com
358: AMAZON.com
359: AMAZON.com
360: AMAZON.com
361: AMAZON.com
362: AMAZON.com
363: AMAZON.com
364: AMAZON.com
365: Baja Forums
366: AMAZON.com
367: AMAZON.com
368: AMAZON.com
369: AMAZON.com
370: AMAZON.com
371: Baja Forums
372: AMAZON.com
373: Pictures
374: AMAZON.com
375: AMAZON.com
376: AMAZON.com
377: My Account
378: Baja Forums
379: AMAZON.com
380: AMAZON.com
381: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- More friggin' questions...
Post Post subject: More friggin' questions...
Posted: Thu Apr 19, 2007 07:26 AM
Ok- here's what I've got so far for rear suspension.
SAW 21 3/4" 28mm torsions (I know- I've been told they're too thick)
Spring plates for short torsions
3x3 arms
Type I trans
What size axle do I need?
What would be the best torsion to use? Topless baja. Mostly street, mild off-road use.
What CV's should I get? Are these a decent unit? Price fair? on ebay
How about these? ebay too
Are all 930 CV's the same???
I still need stub axles. Sheesh, I'm spending a lot of money and I haven't even gotten to the front end yet! (The rear end isn't done yet either!)
Post Post subject: Re: More friggin' questions...
Posted: Thu Apr 19, 2007 03:18 PM
You will need 20 1/4 axles with a T-1 trans & 3x3 arms. The 930 CVs are the way to go if you have the $$$, I bought a set of those from that guy on ebay, very good quality CVs.
The second ebay ad is a bit spendy.
All 930s are the same, but there are a few different boot kits for them (talk to Don at Chirco he can help you with those).
You will need stub axles, and drive flanges for the trans.
Also dont forget the CV bolts, they are different from the T-1
Posted: Thu Apr 19, 2007 04:44 PM
Are the stub axles specific to 930 CVs also? The setup, from trans out, goes: 930 flange/inboard 930 CV/20 1/4" axle splined for 930 CV/outboard 930 CV/stub axle splined for 930 CV, right? And the drum goes on the stub axle? Are outer stub axle splines different? Do I need a specific type of drum because I'm using 930 CVs/stubs, or will T-1 backing plates/brakes/drums work?
Thanks bugzyla...
Posted: Thu Apr 19, 2007 05:12 PM
That first auction price is cheap. (I paid quite a bit more)
Daryll mentioned the rest of the stuff you need. Did the arms you bought have bearings and spacers?
I do not think 28's are too big. You have the shorter bars and longer arms so you need thick to handle the leverage. Chirco's used 27's w/stock arms.
Posted: Thu Apr 19, 2007 05:32 PM
No bearings and spacers or bolts that I can see. Just the poly bushings on the outboard pivots. The spring plates are still attached to the arms- I'm assuming you're referring to bearings and spacers at the inboard pivot point?
I'm going to use the 28's then and see how it goes....
Posted: Thu Apr 19, 2007 09:50 PM
The shorter T-Bars need to be thiner than the longer ones for the same srping rate.
The longer your traling arms the thicker the T-Bars need to be to have the same spring rate.
Posted: Fri Apr 20, 2007 12:35 AM
Here's what you need for the drive axles flange to stub axles.
www.chircoestore.com/c...bc7580cf58
You will need wheel bearings, spacers, seals and bearing retainer c-clips for the arms. And yes the stub axles are different where the cv bolts up to it, but the spline, etc is the same.
Posted: Fri Apr 20, 2007 02:10 AM
Damn DONT! You working on commission at Chirco or something?? Mr. Green My butt hurts!
I better get to shopping- I had no idea it'd be THAT expensive to go 930!
VIN70
VIN70
Posted: Fri Apr 20, 2007 03:40 AM
with 930s 20 1/4 axles may be too long. i would go with 19 1/4.
Posted: Fri Apr 20, 2007 04:19 PM
19 1/4 is for bus trans, 20 1/4 is for type 1. There was a guy on another forum talking about his 20 1/4 bottoming out, but the people who sell the kits for a living say it is the correct size. (But with so many parts coming with no quality control, it is hard to say if 2 parts the same size are the same size.)
I will install mine and see, if too long, a new set is only a phone call away.
(but that will be awhile before the car is ready for them.) Wink
VIN70
VIN70
Posted: Sat Apr 21, 2007 03:40 AM
well i run 19 1/4 without problems, type 1 trans.
best thing to do, is just measure it!
Posted: Sat Apr 21, 2007 05:54 AM
quit pondering and install it already Rolling Eyes
all that chit chat is like being in bed with your wife and tellin her stories before gettin naked.....the moods gone quickly No! No! No! No!!!!
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 4774 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5565 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tow Bar questions 3 ghs215 2325 Tow Bar questions
 Mon Nov 16, 2015 01:45 PM
No new posts New Members New Guy Questions 6 Apoc 4130 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 8201 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
