Visitors: 139
Total: 139
20: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- fan problems
fan problems
milleraj119
milleraj119
Post Post subject: fan problems
Posted: Thu Apr 19, 2007 03:55 AM
fans is hella rubbin i just installed a new right ciylinder tin well i bolted back up the altinnator and all that and it hella rubs and it rubbed before because the right cylinder tin flew off on the freeway i no the fan isent bent or cracked or the fan shroud and the altinator dosent line up with the crank pully and i tried makin line up but dosent wat to move any one want to help me out
Post Post subject: Re: fan problems
Posted: Thu Apr 19, 2007 05:02 AM
somethin is out of whack. take it apart and re assemble.
R.e.J.
R.e.J.
Posted: Thu Apr 19, 2007 09:22 PM
Never had problems with fans,it's the Paparazzi that I find irratating.
On that note,have you checked the doghouse to make sure it isn't bent and causing the fan to rub?
GeneFrenkle
GeneFrenkle
Posted: Fri Apr 20, 2007 09:08 AM
Mine was making a horrible racket. Come to find out, the spacers behind the alternator were in the wrong order. Also, you might have to bend some metal or put more/less shims under the alternator.
1973 VW Bug
1776cc Motor
R.e.J.
R.e.J.
Posted: Sat Apr 21, 2007 11:06 PM
GHAAAA!
I forgot about that.
milleraj119
milleraj119
Posted: Sun Apr 22, 2007 01:16 AM
well i found the problem the fan was cracked bad and so was the metal spacer so i replaces it and it now all works well after i put everyhting back together and went for a test drive i noticed something wasent right and i had lost about half my horse power so i looked around the engine to see what was goin on and i noticed that when i pressed on the gas on the left carb (dual 44 webers) that it was stallin and wasent firen the 3rd and 4th cylinder i felt the exuast tubes on that side and they were cold wich ment my spark plugs were bad so i got new ones and put them on number 3 and 4 cylinder and it ran good well i drove it down the road and it started loosin and jumpin and then died well i started it back up and it lost all the horse power agian and the left side pistons werent firin agian i tired mesin with the air and fual mixture and cleaned the carb and it still isent runnin right im really starten to get mad now i also checked the distributer wires and the all have spark runnin through them and the timing is set and both carbs are syncd
R.e.J.
R.e.J.
Posted: Sun Apr 22, 2007 04:57 AM
Is there a chance that the Driverside carb's float is stuck to where it's not getting gas other than when at idle?
possibly.
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 9066 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
I need some advice...
14 chayes 9715 Re: Baja problems ? ?
 Tue Jun 22, 2010 11:32 PM
No new posts VW Volkswagen & Baja Bug General Discussion brake and aftermarket oil sump problems 5 milleraj119 3595 brake and aftermarket ...
 Thu May 14, 2009 03:17 PM
No new posts VW Volkswagen & Baja Bug General Discussion Carb problems 5 MusicManiac 2415 Re: Carb problems
 Mon Sep 22, 2008 03:10 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Uh-oh front control arm problems... 8 joshsoko92870 3162 Re: Uh-oh front contro...
 Sat Sep 20, 2008 04:03 AM
VIN70 View latest post
