Latest: Sawmer
Overall: 3609
Visitors: 108
Total: 108
18: Home
19: Event Calendar
28: Event Calendar
32: Event Calendar
34: Links
38: Event Calendar
45: Event Calendar
50: Event Calendar
54: Pictures
71: Event Calendar
78: Contact Admin
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- best wiring plan
best wiring plan
tigerextra
tigerextra
Post Post subject: best wiring plan
Posted: Mon Apr 16, 2007 02:42 AM
so im building this rail/super baja ground up, removable body. Im almost at the point for wiring. Ive done a lot of wiring on the hot rods and restorations, usually painless kits or ebay crap modified to my liking. Ive seen a lot of posts, including the really detailed one with pics and im wondering if I should just wire it up on my own custom following the schematics or if theres a basic 10-12 circuit kit out there that people have used and approve of. Im not going to do one with a pre0wired block, those are a pain. But if anyone knows of any decent kits, let me know... either ebay, chirco, factory5, painless etc! thank you! ps there is no stock wiring here ie fuse block, relays, switches, etc :/ (lets keep this here post going, I know a lot of people run into this same issue. Smile
Post Post subject: Re: best wiring plan
Posted: Mon Apr 16, 2007 04:07 AM
Do NOT use the EMPI buggy kit. It has a really crappy fuse box in it. If you have the money use the painless kit, if not get a fuse block from NAPA and wire it to suit you.
GeneFrenkle
GeneFrenkle
Posted: Mon Apr 16, 2007 05:52 AM
Ditto on the EMPI one...I just bought it then scrapped the fuse box for a better one.
It's real simple once you do it. If you worked on the wiring of other cars, you should be able to do this fine.
1973 VW Bug
1776cc Motor
tigerextra
tigerextra
Posted: Mon Apr 16, 2007 08:42 AM
thanks guys, ill probably go with the 12cir. painless hot rod kit. Thats the one i usually use on the willys and cobras, theyre simple enough!
Posted: Mon Apr 16, 2007 04:27 PM
Got the link for the Painless site?
Posted: Mon Apr 16, 2007 06:56 PM
www.painlessperformance.com/
Posted: Tue Apr 17, 2007 08:04 PM
Save the $$$ and do your own wiring kit. All you need is 12 colors of 25 foot length 14 or 16 guage wire , and 1 25 ft length of 10 or 12 guage for the main power, and an aftermarket fuse box. All for about $60.
Posted: Tue Apr 17, 2007 10:25 PM
Where's the best place to buy from Daryll??
Posted: Tue Apr 17, 2007 10:36 PM
you can get the multi roll rack of auto guage wire from harbor freight for perty cheap.
along with a big pack of wire connectors (crimp on forks, eyes, butt splices, etc)
Posted: Tue Apr 17, 2007 11:01 PM
Call Brian at Frontier Shop Supplies, 480-981-1126 and tell him I sent you and you are an AzBaja member and he will hook you up on the wire. I think he can get the fuse boxes too. Or if you wanna buy enough to do your car, I can cut it off of my 100' spools for you.
caversmoon
caversmoon
Posted: Wed Apr 18, 2007 01:55 AM
called him and I am getting the wire. He is checking on the fuse box. Daryll do you have the 10 gage wire in the 100 ft spool.? The smallest he could get was 10 ft. I am buying the 100 count conector, femal blade's, butt and 1/4 circles. These are bare conectors that will have to be shrinked wrapped. I am willing to share. Tom
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 7304 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
Efi to carb
4 bugzapper 4024 Wiring
 Tue Jun 28, 2016 03:16 PM
No new posts Projects and Builds My Plan For A Baja
1964 GMC
40 vwJ420 31914 My Plan For A Baja
 Fri Jan 13, 2012 11:51 PM
vwJ420 View latest post
28 seanoflinn1 13707 Re: Can Somone take a ...
 Mon Jun 14, 2010 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Think I might have a wiring problem? 5 Roadrunner 3495 Re: Think I might have...
 Sun Aug 03, 2008 10:35 PM
sandshark View latest post
