Visitors: 127
Total: 127
13: Home
19: Event Calendar
27: Event Calendar
42: Home
43: Home
72: Home
100: Event Calendar
106: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Showing off the rear cage
Crash
Crash
Post Post subject: Showing off the rear cage
Posted: Tue May 30, 2006 04:46 AM
I spent the last few days getting the rear of my bug mocked up with all new stuff. I just have to finish weld it and complete the trailing arms and I can get this thing on wheels.
-Mark
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Post Post subject: Re: Showing off the rear cage
Posted: Tue May 30, 2006 06:33 AM
I love the use of the Ammo Can and bunngie cords Smile
So the rear traling arms are IRS? Looks like you have moved to a swing axle set up, I do not see the triangle arm coming down from the Torshion houseing.
"Blind Chicken Racing" Cool touch.
Still working the 2.3.... That is always COOL!!!
Crash
Crash
Posted: Tue May 30, 2006 08:07 AM
I am still running IRS. The part you see is only the replacement springplate I built. It will connect to a boxed style 4x5 arm and work similar to a stock one but have the hiem joint instead of the bushings.
-Mark
Mark Johnson
Posted: Mon Jun 05, 2006 05:41 AM
Lookin good! Wink
25 Kreed 26211 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 3758 Re: Max angle for rear...
 Fri Jan 29, 2016 04:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 2358 Rear Rim Backspacing
 Fri Nov 06, 2015 03:13 AM
JWHracing View latest post
what do you use
4 bdrdunes 2882 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
No new posts Projects and Builds Possible rear seat?? 4 TattooedIrish 4211 Possible rear seat??
 Thu Aug 30, 2012 08:55 AM
Rigger View latest post
