Latest: Milkmanbryan
Overall: 3583
Visitors: 171
Total: 171
15: Event Calendar
27: Pictures
36: Groups
40: Pictures
42: Pictures
57: Pictures
64: Groups
99: Pictures
119: Event Calendar
153: Pictures
154: Baja Forums
158: Baja Forums
162: Baja Forums
166: Baja Forums
168: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wiring Loom Kit
Wiring Loom Kit
GeneFrenkle
GeneFrenkle
Post Post subject: Wiring Loom Kit
Posted: Sat Mar 31, 2007 09:22 AM
I bought a wire loom kit a couple of days ago. I think that I would be fine except I can't figure which end of the wire bundle goes up front and which in the back.
Any help????
No! No! No! No!!!!
1973 VW Bug
1776cc Motor
GeneFrenkle
GeneFrenkle
Post Post subject: Re: Wiring Loom Kit
Posted: Sat Mar 31, 2007 10:14 AM
...and while we're at it, if you take the ignition switch off of the steering column, will it prevent the steering wheel from locking without the key?
If so, I may just put a new ignition switch in it as well.
Then...the next problem will be figuring out the blinker switch.
1973 VW Bug
1776cc Motor
GeneFrenkle
GeneFrenkle
Posted: Sat Apr 07, 2007 12:19 AM
If you buy the wire loom kit that comes from EMPI, the end with the blue connectors goes to the rear of the car.
If you take the whole piece that holds in the ignition switch, you will need to take the bushing out of the housing and hold it in place with a hose clamp. If you buy the turn signal switch from EMPI, the stock flasher relay will not work (unless mine was broke).
Had to answer my own question, but someone might search for this answer later.
1973 VW Bug
1776cc Motor
azhunter
azhunter
Posted: Sat Apr 07, 2007 06:21 AM
I couldn't answer cuz I did away with the whole column. Just using the stock shaft for now with a bolt on bushing. Glad to hear bout' the wiring kit though. It didn't come with instructions?
GeneFrenkle
GeneFrenkle
Posted: Sun Apr 08, 2007 06:11 AM
Nope...just a schematic. I realize that should be enough, but just a few pointers would have been nice.
1973 VW Bug
1776cc Motor
azhunter
azhunter
Posted: Sun Apr 08, 2007 06:41 AM
Scematics can be an SOB! No! No! No! No!!!! I have yet to wire my bug as I have to incorporate the ford harness. Glad you got it done though.
GeneFrenkle
GeneFrenkle
Posted: Sun Apr 08, 2007 07:08 AM
Now that I have done it, I think I could do it better by just buying the stuff and doing it from scratch.
Just took my bug to the dunes for the first time today. No one told me you aren't supposed to try to jump a bug with a stock front end at 25-30mph+. We cleared about 25 feet but ended our day early by bending a tie rod BADLY. We were able to bend it back and tow it home...It was worth it! A lot of fun today. I will post pictures of my tie rod in a new post.
1973 VW Bug
1776cc Motor
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5376 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
Efi to carb
4 bugzapper 2609 Wiring
 Tue Jun 28, 2016 03:16 PM
28 seanoflinn1 11037 Re: Can Somone take a ...
 Mon Jun 14, 2010 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Think I might have a wiring problem? 5 Roadrunner 2746 Re: Think I might have...
 Sun Aug 03, 2008 10:35 PM
sandshark View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VDO Guage Wiring Diagrams 1 BugZyla.com 2741 Re: VDO Guage Wiring D...
 Sat Feb 16, 2008 10:21 PM
jamesr6168 View latest post
