Visitors: 109
Total: 109
23: Event Calendar
59: Event Calendar
81: Event Calendar
97: Event Calendar
98: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Needing misc Baja info please
planenutz
planenutz
Post Post subject: Needing misc Baja info please
Posted: Fri Apr 06, 2007 10:42 PM
Just PCS'd to Tucson and need to get my Baja inspected by the DMV. The pan VIN and the title don't match; where else might I find a VIN on the body? Its a 65 (according to the title). KP front & IRS rear.
Also need to get new tires. What do you recomend for on/off road use around here? The centerline rims I have are pretty wide - has L78-15's on the back and normal width fronts.
Thanks
vwbill
vwbill
Post Post subject: Re: Needing misc Baja info please
Posted: Fri Apr 06, 2007 10:48 PM
Early body vin plates were in the well under where the spare tire sat. Later they were moved to the dash, visible through the windshield.
William
planenutz
planenutz
Posted: Fri Apr 06, 2007 11:29 PM
So, with no VIN on the dash and the front cut for the 1 piece Baja front end, I'm SOL on an body VIN? So Sad
Posted: Fri Apr 06, 2007 11:53 PM
So Sad So Sad So Sad doesn't sound good. vin attached to the pan is the important one.
Posted: Sat Apr 07, 2007 12:56 AM
a 65 vin is stamped on the center tunnel behind the front seat!!!!
you will see the access pamnel for the shift rod coupling. the vin is right there.!!!!!!!
planenutz
planenutz
Posted: Sat Apr 07, 2007 03:35 AM
I found the VIN (it was under where the previous owner welded a battery tray). Embarassed
It matches the title! Now I just need to fix:
the nonexistant brakes
buy new tires
fix the rt rear wheel bearing
install wiper arms & linkage
THEN I can drive it to DMV and license it Smile
Posted: Mon Apr 09, 2007 04:32 PM
buy new tires
Piece of cake compared to a vin mismatch headache!!
5 Admin_AzBaja 7342 Baja Bugs on Wiki need...
1568 mufasavnvmc 1020353 Re: what did you do to...
285 MusicManiac 246360 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 469 FREE VW BAJA'S
0 Northmountainauto 1780 Shop Baja
