Visitors: 122
Total: 122
18: Event Calendar
26: Event Calendar
32: Home
38: Event Calendar
39: Event Calendar
46: Event Calendar
59: Event Calendar
60: Home
62: Home
67: Event Calendar
89: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- ???What should I do, paint or Rhino Line???
mongeey
mongeey
Post Post subject: ???What should I do, paint or Rhino Line???
Posted: Fri Mar 23, 2007 05:00 AM
This is the back behind the rear seat. It's all rusted and gross, it scares my kid, he doesn't like to sit in the back seat, should I paint it black...or just rhino line it with the can stuff from pep boys, I figure if I paint it I will spend 3 days trying to clean it to make it a nice finish, w/the Rhino line, it adds texture, so cleaning won't be too much of a hassle....what do you guys think???
Post Post subject: Re: ???What should I do, paint or Rhino Line???
Posted: Fri Mar 23, 2007 05:20 AM
YOUR GOING TO HAVE TO CLEAN IT UP SOME FOR ANYTHING TO STICK, TAKE A DRILL AND WIRE BRUSH, CLEAN IT UP SOME SOMETHING THAT WORKS GREAT IS RUSTOLIEM BRUSH ON PAINT,THE RED PRIMER, YOU CAN PAINT IT RIGHT OVER RUST, HAVE FUN!!
Posted: Fri Mar 23, 2007 05:50 AM
some of that looks to be a bit deep. either bead blast it all off or wire wheel as suggested (just wear a good dust mask for the rust dust will hurt). once its cleaned up, go from there.....
Posted: Fri Mar 23, 2007 04:29 PM
This is what I like to use, knock off the loose stuff and paint this right over the rust! www.por15.com/
After you put the initial coating on, you need to top coat it because it is sensative to uv.
It is not the cheapest, but you don't need too much for the area you are doing.
mongeey
mongeey
Posted: Fri Mar 23, 2007 09:03 PM
Here is the pic. of it cleaned up:
And here it is all painted!!
New Die Grinder $64, can of spray paint $3....Realizing there is more rust here than in an iron scrap yard.........PRICELESS!!!!\
I have to admit, it's pretty freakin' good, okay, it looks like I cleaned and spray painted it, but at least it's not scary anymore Mr. Green
Posted: Fri Mar 23, 2007 10:24 PM
You sure work quick Smile Looks good already.
Oldbug59
Oldbug59
Posted: Sat Mar 24, 2007 03:32 AM
A Buddy of mine painted his entire car with the spray on under coating and then painted over that with black Hammerite. It looks Bad ass.
The work you've done looks good too. I have to agree with DONT. You work quick.
74 Super Beetle Daily Driver
Projects
63 Sunroof
59 Sedan (Gettin Baja'd)
azhunter
azhunter
Posted: Thu Apr 05, 2007 05:39 AM
Check this out. I've used the rust converter before, works great. I know, I know. day late, dollar short. Rolling Eyes
www.eastwoodco.com/jum...itemID=372
4 Pointvirus 5533 paint schemes
 Sat Apr 28, 2012 08:17 PM
Pointvirus View latest post
No new posts VW Volkswagen & Baja Bug General Discussion New paint job on my car. 3 Ejbbal21 2895 Re: New paint job on m...
 Wed Mar 07, 2012 08:31 PM
No new posts VW Volkswagen & Baja Bug General Discussion The Cow Bug's New Paint 10 Lucky7-11 9512 Re: The Cow Bug's New ...
 Sun Sep 04, 2011 05:55 PM
Ken48442 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion No Rust Paint? 4 Bryman042 5230 Re: No Rust Paint?
 Sat Mar 05, 2011 04:04 AM
No new posts VW Volkswagen & Baja Bug General Discussion Line X 4 JVAZ 2755 Re: Line X
 Wed Aug 11, 2010 07:29 PM
JVAZ View latest post
