Visitors: 102
Total: 102
13: Event Calendar
78: Event Calendar
90: Pictures
91: Pictures
98: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- How do I?
How do I?
Post Post subject: How do I?
Posted: Tue Mar 27, 2007 07:10 AM
dismantle the swingaxle rear suspension on my pan without killing myself? Aren't the springplates under tension? All that's left on the pan are the springplates and I guess the torsion bars are inside the housing, right? I'm converting to IRS- the pivot brackets are already in place.
Post Post subject: Re: How do I?
Posted: Tue Mar 27, 2007 08:18 AM
theres a topic on that here some wherez.....
Posted: Tue Mar 27, 2007 09:57 PM
Point taken. I'll search. So Sad
Posted: Wed Mar 28, 2007 02:51 AM
If you would like to borrow a torsion bar tool, let me know. It bolts to the body mount and has a hook to hold the spring plate.
Or if the car is supported with the spring plate free, a large prybar will get it off the stop. Just have to make sure nothing can be hit by the plate as it comes down with the force of a scorn woman!
Posted: Wed Mar 28, 2007 03:01 AM
Use the tool, it's good. I normally use ratchet straps, not a good idea, but I still have all of my fingers!!! (for now)
It's not as scary as people make it out to be. Just be careful. There is a great write up in Baja Bugs and Buggies.
Posted: Wed Mar 28, 2007 04:11 AM
So, using the tool, you're basically going to pry it up, slide it over the hook, and let it gently travel down past the hook, relieving the tension in the torsion bar, right? Seems logical anyway. When the tension is off, you can just take it apart, right?
Posted: Wed Mar 28, 2007 05:46 AM
sorry, i was distracted and forgot to search......
Posted: Wed Mar 28, 2007 07:52 PM
Yes, you got it! Just let me know.
