Latest: xbluegto
Overall: 3573
Visitors: 190
Total: 190
01: My Account
03: Event Calendar
20: Event Calendar
22: Event Calendar
62: Event Calendar
130: Event Calendar
132: Event Calendar
133: Event Calendar
139: Event Calendar
145: Pictures
162: Baja Forums
177: Baja Forums
180: Event Calendar
183: Baja Forums
184: Baja Forums
185: Event Calendar
190: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Question about Baja Bug Bumpers
carpe_cerveza
carpe_cerveza
Post Post subject: Question about Baja Bug Bumpers
Posted: Tue May 30, 2006 07:54 PM
Looking for general info on bumpers for Baja Bugs. I just bought a 1968 Baja that has no bumpers and want to fit it out so as not to damage the engine. So my questions run along the lines of... Are there different brands and if so does one stand out as best? Do they all mount the same (and universally)? Do I need a "heavy duty" type or is that just extra weight? Are they all skid plate compatable? Thanks for any info you can give me.
Post Post subject: Re: Question about Baja Bug Bumpers
Posted: Tue May 30, 2006 08:57 PM
Whatever bumpers you choose you will have to do some fabricating to get them to fit. There are basically two ways to mount rear bumpers, shock mount and firewall mount. I like the firewall mount better (they're stronger) but you will have to fab up some reinforcements. The shock mount bumpers mount to the top of the rear shocks, and are easier to install, but because they crimp the tube flat to make to mount to the shock bolt they tend to break.
Besides mounting points there are double and single tube bumpers. Simply put more material=more strength=more weight. I wouldn't worry about weight, the added strength outweighs (pun intended) any speed gains that you might get from the ten to fifteen pounds that you would save.
Every ting is skid plate compatible as long as you weld!!!
4 Admin_AzBaja 5698 Baja Bugs on Wiki need...
1568 mufasavnvmc 902544 Re: what did you do to...
285 MusicManiac 218741 Re: Baja sightings
0 Northmountainauto 241 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1468 Baja hiding in Chandle...
