Visitors: 94
Total: 94
40: Home
41: Home
53: My Account
89: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Where to mount my 5 point harnesses?
Billy
Billy
Post Post subject: Where to mount my 5 point harnesses?
Posted: Sun Mar 18, 2007 08:24 PM
Ok I just got done putting in my seats, they're from a Toyota or something I'm pretty sure. Now I have these 5-point 3x3 Crows that I have to put in but the straps ain't that long. I can post pictures of the ordeal if needed, but has anyone else installed these or something similar? Any ideas? Right now the idea that we're probably gonna do is weld angle iron just below the rear window fron one side to the other and bolt them to it. What do you think? Again, I can post pictures if needed.
Post Post subject: Re: Where to mount my 5 point harnesses?
Posted: Sun Mar 18, 2007 08:29 PM
see this: www.chircoestore.com/c...ts_id=4552
Billy
Billy
Posted: Sun Mar 18, 2007 09:05 PM
That same diagram is printed o the back of the box that the restraints come in. I know about the angles and all, but the shoulder restraints only reach so far, theres nothing to mount them to unless I go custom, I just need to know the best way of doing so. The lap part looks like it'll be fine in on the stock lap belt mounting holes and the stock seat mount pyramid will serve as a mount for the crotch strap.
Posted: Sun Mar 18, 2007 09:43 PM
you will need a bar across the back of the seats to mount the should straps to.
it should tie into a roll cage if so equiped.
Billy
Billy
Posted: Mon Mar 19, 2007 04:12 AM
I have a roll cage- 4 point. So you think I outta maybe incorporate the bar below the horizontal bar on the top (if that mades sense)
Posted: Mon Mar 19, 2007 05:19 AM
Belts do not mount to the seat!!! mount them to hard points in the car. if you mount them to the floor/sheet metal use big fat 3" fender washers on both sides of the anchor bolt.
It's your Ass you want to save...
Posted: Mon Mar 19, 2007 08:07 AM
YOU GOT TO ASK YOUR SELF, HEAVEN FORBID, BUT IF I ROLLED THIS THING OVER A FEW TIMES WOULD.....1. WILL THESE SEATBELTS HOLD ME IN ?? OR ...2. WILL THEY SHOOT ME OUT OF THE CAR LIKE A 3" CROW SLING SHOT!! I HAVE 5POINT CROWS I MOUNTED THIS LAST WEEK SOME FAB WILL NEED TO BE DONE . JUST MOUNT ALL FIVE POINTS TO SOILD POINTS NOT SEAT. WITH ALL 5 HOLDING YOU IN YOUR NOT GOING ANYWHERE!!
Posted: Mon Mar 19, 2007 04:55 PM
To add to the above, yes, measure your shoulder line and weld in a crossbar to mount the shoulder harness to. NOT angle iron or anything with an edge!
Billy
Billy
Posted: Mon Mar 19, 2007 06:00 PM
No no, nothing is being mounted to the seat. The lap belts are going into the stock belt holes, and crotch strap is being mounted onto the stock seat mount (its a 74, it has that pyramid thing for a mount). The seat is not attached to the seat mount, made custom mounts cuz they're like Toyota seats or something. Thanks for the tips folks
No new posts VW Volkswagen & Baja Bug General Discussion Center Mount Fan Shroud 4 Darn_Near 3207 Center Mount Fan Shrou...
 Sat Apr 12, 2014 05:13 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion dellorto 36 center mount 2 _-Mad-Max-_ 2713 Re: dellorto 36 center...
 Tue Jun 19, 2012 03:38 PM
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 13083 best way to mount a li...
 Mon Feb 07, 2011 02:31 AM
woodin View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fabbed new plate mount and light 9 Tcatdrv 4176 Fabbed new plate mount...
 Sun Jul 04, 2010 07:41 PM
Tcatdrv View latest post
No new posts Projects and Builds JWHracing builds a spare tire mount 3 JWHracing 7474 Re: JWHracing builds a...
 Tue Jun 16, 2009 06:49 PM
JWHracing View latest post
