Visitors: 97
Total: 97
03: Event Calendar
82: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- just got started
just got started
bigsam
bigsam
Post Post subject: just got started
Posted: Sat Mar 17, 2007 07:56 AM
I aquiered a 1964 vw bug on 02/12/07. most of the inportant stoff was there lights, trans, moter 1600cc non running , and most inportent the pinkslip!! it had alot of extras such as 3 carb setups stalk, progresive, and webber 44. the previs owner installed a new trans in 02 with 4.12 dif, 3.80 1st gear, 2.06 2nd gear, 1.31 3rd gear, and a .82 4th geag. so i was happy with the perches 1000 duckets Smile .
I just got it running today. after putting new slives and pistons in it. replaced the tins also. I used the webber 44 carb setup. I had a problem with some of the wireing. No! No! No! No!!!! the oilcooler fan had ben okeyriged with a togel switch just laying on the floor next to the parking brake. I couldn't get a strate ansore on the oiltemp switch on how to wire it back in, so i put a new switch on the dash with an endacater light to let me know it's on or not.
I,m not done yet. just got started on the prodject. the brakes sill need to be done. needs a fender kit, some chopping, and lifting, paint, and a rollcage.so like the titel just got started.
DRIVEIT LIKE YOU
STOLE IT
Post Post subject: Re: just got started
Posted: Sat Mar 17, 2007 09:49 AM
electric oil cooler fan????
no dog house fan that is turned by the engine????
bigsam
bigsam
Posted: Sun Mar 18, 2007 10:35 PM
new doghouse i replaced it with the tins, but the previous oner took out the oil cooler and installed this one from a truck, its a trans cooler. Confused he told me that he did this becouse the stolk oil cooler made the 3rd cilender over heat. so i just went with it. Neutral is that ok, or should i put the stalk one back in?
DRIVEIT LIKE YOU
STOLE IT
Posted: Mon Mar 19, 2007 01:05 AM
if cyl #3 wasnt cooling enough with a stock doghouse and cooler, then somehting was out of wack. many aircooled guys run doghouse and fan with no probs.
make sure the tins fit tight around each other, screw then together if ya need. I did that where the bottom cyl tins meet the doghouse. forms a better air flow.
bigsam
bigsam
Posted: Mon Mar 19, 2007 02:03 AM
I replaced all the tins all thew tins because they looked like hammered dog sh.. .there wasent even aney screws holding them on just the fan belt holding the alternator. Embarassed the strap for the alt. wasn't even on properly. I now have all new srews for the tins. the ones that hold the tins to the heads 4 total and the 2 that hold the dog house to the tins. but thanks for the tip I willscrew cloesed the small gap it was bouthering me anneyways. Very Happy
DRIVEIT LIKE YOU
STOLE IT
Posted: Mon Mar 19, 2007 02:17 AM
you just told us why CYL # 3 was OVERHEATING!!! Wink Very Happy
No new posts VW Volkswagen & Baja Bug General Discussion Just getting started
general info
13 bajaben1 8910 Re: Just getting start...
 Wed Mar 23, 2011 10:25 PM
bajaben1 View latest post
No new posts Projects and Builds just getting started
lil woody
5 mikey 3124 Re: just getting start...
 Fri May 07, 2010 04:23 AM
No new posts VW Volkswagen & Baja Bug General Discussion Getting Started (hopefully this weekend) 4 anhedonite 2336 Re: Getting Started (h...
 Fri Sep 07, 2007 05:39 AM
No new posts VW Volkswagen & Baja Bug General Discussion Getting Started 11 R0B_Z0MBIE 3588 Re: Getting Started
 Tue Jan 16, 2007 01:18 AM
No new posts New Members Getting Started 2 Sport 1387 Re: Getting Started
 Sun Aug 27, 2006 09:23 AM
Sport View latest post
