Latest: George
Overall: 3576
Visitors: 105
Total: 105
17: Home
47: Pictures
58: Home
72: Home
77: Event Calendar
96: My Account
101: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Is this a good buy for a trans?
Post Post subject: Is this a good buy for a trans?
Posted: Thu Mar 15, 2007 06:19 PM
Craigslist 090? bus trans for sale
Just wonderin' if this would be adequate for me... I know NOTHING about these things, just that I heard BUS is better than BUG when it comes to transaxles. I know I need a front-shift and not side, blah blah blah...
HELP!
Thanks,
Tony
Post Post subject: Re: Is this a good buy for a trans?
Posted: Thu Mar 15, 2007 06:20 PM
to go bus you need to make a new mount for it. $300 is pretty cheap! if ya want it get it before bugzyla!!
Posted: Thu Mar 15, 2007 07:11 PM
By "new mount" you mean alter the horns that the tranny sits on? Is there a weld-on kit for that, or do you find a donor bus and hack it off of there?
Posted: Thu Mar 15, 2007 07:17 PM
whats the reason for upgrading ? just want to ? your bug tranny is pretty strong as long as you dont abuse it. if your installing a larger engine like a stroker or water cooled buy the 009...imho is it going in a rail or bug ?
Posted: Thu Mar 15, 2007 07:24 PM
I'm just building a 1835 or so street legal trail baja. Would like some decent suspension, but won't be racing or abusing it too much at all. Might get off the ground for about one second once in a great while, but that's about it...
Think a bug IRS tranny will suffice? I HATE to underbuy for what I'm doing, then regret it later... If a minor mod is in order now, while the pan's bare naked, in order to avoid headaches and broken crap later, then I'm all for it...
Thanks for the input!
Posted: Thu Mar 15, 2007 07:52 PM
There are 2 ways to mount them. One is a bolt in kit which puts your shift tube above the tunnel, so you mount a shifter box above the tunnel. The other is a 10 degree mount, you have to weld it in, tilts the front down, rear up 10 degrees (imagine that, just like the name!) the shift tube stays in the tunnel, quite a bit of cutting, fitting and welding, you also loose 1 1/2 to 2 inches of rear travel due to the new location of the output flanges.
KCnaz is installing a 10 degree and has pictures, I just didn't look for it when typing this.
BTW 300 is an average to good depending on condition. It looks nicely painted.
Posted: Thu Mar 15, 2007 08:32 PM
by all means buy it. im the same way, lil' pain now, instead of a big pain later...here's the 10* mount
azhunter
azhunter
Posted: Fri Mar 16, 2007 12:33 AM
That doesn't look like any 090 I've ever seen before. Not a bad deal though.
29 AzBaja 29121 Re: "AzBaja Supporting...
 Mon Mar 09, 2009 07:32 PM
cyberjaw4 View latest post
8 AzBaja 2618 photobucket.com is a n...
 Fri Jul 07, 2017 11:37 PM
51 Yummi 25396 Doing good things for ...
 Sat Dec 14, 2013 10:00 AM
No new posts VW Volkswagen & Baja Bug General Discussion made a good score......... 1 vtbaja 1695 Re: made a good score....
 Wed Oct 09, 2013 12:19 AM
No new posts VW Volkswagen & Baja Bug General Discussion Doing good things for a Marine 2 Yummi 2321 Doing good things for ...
 Sun Sep 15, 2013 04:53 AM
