Latest: strike77
Overall: 3575
Members: 1
Visitors: 384
Total: 385
 Members:
01: JWHracing > Home
02: Event Calendar
03: Event Calendar
05: Event Calendar
07: Event Calendar
08: Event Calendar
18: Pictures
33: Pictures
65: Event Calendar
67: Event Calendar
71: Event Calendar
72: Event Calendar
76: Event Calendar
77: Event Calendar
78: Event Calendar
80: Event Calendar
116: Pictures
154: Baja Forums
157: Baja Forums
158: Baja Forums
177: Baja Forums
178: Baja Forums
179: Event Calendar
180: Baja Forums
182: Baja Forums
184: Baja Forums
187: Baja Forums
189: Baja Forums
190: AMAZON.com
191: Baja Forums
194: Baja Forums
196: Baja Forums
197: Baja Forums
198: Baja Forums
199: Baja Forums
200: Baja Forums
201: Baja Forums
202: Baja Forums
203: Baja Forums
204: AMAZON.com
205: Baja Forums
207: Baja Forums
208: Pictures
209: Baja Forums
210: Baja Forums
211: Baja Forums
212: Baja Forums
213: Event Calendar
214: Event Calendar
216: Event Calendar
218: AMAZON.com
219: Event Calendar
220: Event Calendar
221: Event Calendar
222: Event Calendar
223: Event Calendar
224: Event Calendar
225: AMAZON.com
226: Event Calendar
227: Event Calendar
228: Baja Forums
229: AMAZON.com
230: Event Calendar
231: Event Calendar
232: Event Calendar
233: Event Calendar
234: Event Calendar
235: AMAZON.com
236: Event Calendar
237: Event Calendar
238: Event Calendar
239: AMAZON.com
240: AMAZON.com
241: Event Calendar
242: Event Calendar
243: AMAZON.com
244: Event Calendar
245: Event Calendar
246: Event Calendar
247: Event Calendar
248: Pictures
249: Event Calendar
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: Baja Forums
256: Baja Forums
257: Baja Forums
258: Event Calendar
259: AMAZON.com
260: Pictures
261: Event Calendar
262: AMAZON.com
263: AMAZON.com
264: Event Calendar
265: AMAZON.com
266: Event Calendar
267: Event Calendar
268: Baja Forums
269: Event Calendar
270: AMAZON.com
271: Event Calendar
272: Baja Forums
273: AMAZON.com
274: AMAZON.com
275: Event Calendar
276: AMAZON.com
277: AMAZON.com
278: Event Calendar
279: AMAZON.com
280: Event Calendar
281: Baja Forums
282: AMAZON.com
283: Baja Forums
284: AMAZON.com
285: Baja Forums
286: Baja Forums
287: Baja Forums
288: Baja Forums
289: Baja Forums
290: Baja Forums
291: AMAZON.com
292: Baja Forums
293: Baja Forums
294: Baja Forums
295: AMAZON.com
296: Baja Forums
297: AMAZON.com
298: Baja Forums
299: AMAZON.com
300: Pictures
301: Event Calendar
302: Baja Forums
303: Baja Forums
304: Pictures
305: Event Calendar
306: Event Calendar
307: Event Calendar
308: AMAZON.com
309: Event Calendar
310: AMAZON.com
311: Baja Forums
312: Baja Forums
313: Baja Forums
314: AMAZON.com
315: Baja Forums
316: AMAZON.com
317: Baja Forums
318: Baja Forums
319: AMAZON.com
320: Event Calendar
321: AMAZON.com
322: Baja Forums
323: Baja Forums
324: Baja Forums
325: Baja Forums
326: Event Calendar
327: Baja Forums
328: Baja Forums
329: Baja Forums
330: Baja Forums
331: Baja Forums
332: Baja Forums
333: AMAZON.com
334: Baja Forums
335: Baja Forums
336: Baja Forums
337: Baja Forums
338: Event Calendar
339: AMAZON.com
340: AMAZON.com
341: Event Calendar
342: Event Calendar
343: Event Calendar
344: AMAZON.com
345: Event Calendar
346: AMAZON.com
347: Baja Forums
348: Baja Forums
349: Baja Forums
350: AMAZON.com
351: Baja Forums
352: Event Calendar
353: Baja Forums
354: Event Calendar
355: Event Calendar
356: AMAZON.com
357: Event Calendar
358: Baja Forums
359: Baja Forums
360: Baja Forums
361: AMAZON.com
362: Event Calendar
363: Baja Forums
364: Baja Forums
365: AMAZON.com
366: Baja Forums
367: Baja Forums
368: Baja Forums
369: Baja Forums
370: Baja Forums
371: Baja Forums
372: AMAZON.com
373: Baja Forums
374: Event Calendar
375: Event Calendar
376: Pictures
377: Baja Forums
378: AMAZON.com
379: AMAZON.com
380: Baja Forums
381: Baja Forums
382: AMAZON.com
383: Baja Forums
384: Baja Forums
1 2 3 ... 103 104 105
mufasavnvmc
mufasavnvmc
Posted: Mon Mar 12, 2007 02:22 AM
I will start. It was a pretty nice day still have snow on the ground in places. I removed my front beam and cut off the shock towers and the suspension stops. Torn down all components. Cleaned up the beam in preperation for welding on new towers and installing adjusters. It all came apart alot easier than I thought it would. Hope it goes back the same. Razz Razz Razz
Mufasa
azhunter
azhunter
Posted: Mon Mar 12, 2007 03:44 AM
Cleaned the trans I'm putting in my baja. Bought an 002 from kcnaz saturday, good deal and couldn'y pass it up. And thats all I have to say bout' that!- Forrest Gump Smile
R.e.J.
R.e.J.
Posted: Mon Mar 12, 2007 05:41 AM
Well,it was kinda nice out today,so when I got home I wandered over to the neighbers house and watched/helped a little with his mazda auto to stick swap(Help - distracting him with talk mostly),then wandered back over to the house.Set the card table up in the garage and away assorted parts and tools from Harbor Freight and parts store to get ready for the carb swap on the VW.
When brought the aftermarket 34PICT intake center back over to the neighbor to show him(And complain about how I had to take the die grinder to crappy forging).
He suggested I clean up the throat to get rid of the flashing there too.
So I put it back into the garage and will pick up some sanding things for the die grinder to clean up the throat tommorow.
And maybe see if I can make the epoxy dissaper so I can take it apart and smooth out the mating surfaces inside where the pipes mate up with the aluminum,and re-epoxy the pipes back in STRAIGHTER than they are now.
Sooo Today,jabber with the neighbor and set up card table...YAY ME!
Posted: Mon Mar 12, 2007 08:14 AM
Drove mine.
Posted: Mon Mar 12, 2007 08:25 AM
moved it from yard to drive way
Posted: Mon Mar 12, 2007 04:50 PM
Posted: Mon Mar 12, 2007 08:01 PM
Posted: Mon Mar 12, 2007 09:26 PM
Finished welding on the new floor pans, cleaned up welds and primered.
Still need to seal with Silicon/RTV yet.
Posted: Mon Mar 12, 2007 09:40 PM
I am excited to say that I got my baja running. I have a 72 super beetle that I have learned to tinker on over the past year, but my heart has always been set on getting a baja.
About a month ago, I traded an old pickup truck for a 72 standard. The bug had dents in the fenders and the brake pedal assembly was frozen. The engine needed a tune as well. It had been sitting for quite some time.
Last week, I installed a used bug eye kit that Bugzylla sold me, and rear fenders that VIN70 sold me, and yanked out the engine. This past Saturday, I pulled the known good engine in my Super beetle and installed it in the baja. I changed out the exhaust and pulley. I swapped the rear shocks as well, putting coil overs on the rear of the baja.
Yesterday, I swapped carbs because I couldn't get my 34pict3 to idle. I put a 30/31 on with an adaptor that I had. Set the timing and hooked up the headlights, turn signals and mounted one of the factory tail lights. I am still waiting on pigtails from VIN70, or I would have hooked up the recessed lights in the rear fenders. Swapped pedal assemblies as well. Took it to work today, and what a difference!
This buggy is nimble and quick. It is the same engine, literally, as was in the Super beetle. But what a difference! Sure is fun!
Now I need to do some sanding an paint. I need some 235/75R15's. Hope to find 2 cheap. Bugzylla has some new ones I might buy, but the budget's thin. Anyone have a couple they want to part with?
mufasavnvmc
mufasavnvmc
Posted: Tue Mar 13, 2007 04:02 AM
Hi again, Today I welded in my new shock towers, and started gussets I hope to have time tomorrow put in the new adjusters. Then it will be time to figure out my suspension stops. This more fun than I thought it would be. Thanks again for all of your advice. Mufasa
Bahaw
Bahaw
Posted: Tue Mar 13, 2007 06:00 AM
Well, since I have been unable to sell my baja, I decided to keep it. So, I installed a pair of KCs on the roof, installed the windshield and rear glass with new rubbers, painted the nerf bars and got the left one mounted. I would have gotten the right side mounted too, but found the old bolts are broken off in the bug. Arrrrrrrrrgh!!!!
BTW, I hate installing the glass! I broke the original windshield while installing the new seal and had to get a new one at BAP today. Bummer...
Next, I will get the brakes working, wire in the KCs, weld tail light mounting brakets to the rear cage, install tail lights, weld in rear floor patch panels and re-wire the beast. Oh, I still need to get a pair of headlights mounted & wired up.
Jake
Posted: Tue Mar 13, 2007 07:34 AM
GOT THE LIGHTS,BREAK,TURN, ECT ALL FINISHED THIS WEEKEND, GOT THE FRONT TILT END ALL SANDED AND PRIMERED. REAR FENDERS AND BACK ENGINE COVER PRIMERED ALL THATS LEFT IS THE TWO DOORS THEY NEED A LITTLE MORE WORK. WENT TO CIRCOS TODAY AND MET THE FELLOWS. NICE GROUP. DON WAS HIDING IN OFFICE. PICKED UP A SET OF TIE RODS AND ENDS FOR 66. BUT TO DAMN LAZY TO INSTALL TONIGHT, TOMMORROWS GOOD. PICKED UP A FEW THINGS FOR BUGZYLLA WHILE THERE ,HEY I HOPE YOUR PARTS SLIDE TOGETHER LIKE BUTTER !!
R.e.J.
R.e.J.
Post Post subject: Raspberries the guys driving thier Bajas
Posted: Tue Mar 13, 2007 08:14 PM
Well last night I took the No-Name center to work and ran a scotch brite wheel inside the manifold's carb base thoat(For lack of proper name).
Then washed it out by running a rag through it in the wash tank and blowing it out.
Today after lunch I begin the wrenching on the Bug.
Oldbug59
Oldbug59
Posted: Tue Mar 13, 2007 08:33 PM
Just recently decided to Baja my 59 sedan. I've had the body off the pan for quite a while. The fenders are off...it's basically a shell. I put the front fenders on the rear with just a couple of bolts, marked where I think I need to cut. Started doing some sanding to clean up some dings..... I don't get as much time to work on MY projects as I do with others....if you know what I mean.
74 Super Beetle Daily Driver
Projects
63 Sunroof
59 Sedan (Gettin Baja'd)
Posted: Tue Mar 13, 2007 09:16 PM
4 Admin_AzBaja 5897 Baja Bugs on Wiki need...
285 MusicManiac 223557 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 1 azdesertrat87 57 Re: Had to go play in ...
 Mon Jul 16, 2018 08:00 PM
0 Northmountainauto 655 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2290 Baja hiding in Chandle...
