Latest: kevinbaja68
Overall: 3591
Visitors: 98
Total: 98
27: Event Calendar
53: Event Calendar
89: Event Calendar
94: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- give me a BRAKE
give me a BRAKE
Post Post subject: Re: give me a BRAKE
Posted: Wed Feb 28, 2007 02:06 AM
NOT LOOKING FOR CREDIT GUYS JUST WANT TO LET YOU KNOW THAT I KNOW A LITTLE SOMETHING !! AND A WHOLE LOT ABOUT NOTHING!!! I ONLY HOPE IT FIXES THE PROBLEM!! IT REALLY HARD TO STOP A VW WITH YOUR FEET!!
bajafreaks
bajafreaks
Posted: Wed Feb 28, 2007 04:32 AM
I have a 68 so my resevour is on the inner fender well. When I bench bleed do I just keep the m.c. full of fluid at all times until I pump fluid out the fittings. What about a brake bleeder. Would that possibly work rather than taking the m.c. out???
Posted: Wed Feb 28, 2007 04:40 AM
guessin you could bench bleed it while its on the car. just disconnect the brake lines from it to avoid air down line.
use the pedal to press the cyl vs a screw driver.
WHEN I BENCH BLED MINE, I CLAMPED IT IN A VICE, PUSHED IN THE PLUNGER, FILLED RESOVOR, THEN LET OUT PLUNGER A LITTLE AT A TIME MAKING CERTAIN THE RESSTAYS FULL THE WHOLE TIME,THIS WILL GET IT TO THE POINT WHERE REG BLEEDING (wheel cly) WILL WORK JUST FINE.
Posted: Wed Feb 28, 2007 04:43 AM
now i have been told of a way to change a massa cylinder without bench bleeding it first. Im not so privy to the "top secret" mechanics info yet. I just have to call my big bro and ask....
<----- lazy ars!
bajafreaks
bajafreaks
Posted: Wed Feb 28, 2007 04:49 AM
I like the idea of leaving it in and just disconnecting the lines.
bajafreaks
bajafreaks
Posted: Thu Mar 01, 2007 02:23 AM
Okat I pulled off the lines and pumped the brake peddle about 12 times. I hooked everything back up and blead them again, they got a little better so then I recided to clamp the two rubber lines in the rear, after pumping on them just a few times I got the pedal to come up about half way. I then took off the vise grips and they went back to the same old shit. Also for some reason the shoes keep loosing up after I've adjusted them. I'm runnin out of ideas. Thanks again for the help!!!!
Posted: Thu Mar 01, 2007 03:28 PM
Are the tabs that hold the adjusting wheels there? Are they tight? If they are there and fit tight, the shoes should not back off! Since all the air is out of the system now, the pedal should be effected by shoe adjustment.
I wonder if your old master cyl had a residual valve in it and your new does not.
sickbaja68
sickbaja68
Posted: Tue Mar 06, 2007 04:02 AM
Dude, I am going through the same thing. I replaced all my wheel cylinders, shoes, drums, soft and hard lines, resivor. I did the buddy system and guess what the master cylinder is still good. Lifted up the carpet and my main hard line that runs along the tunnel inside the baja is leaking all over. I need to replace that and I should be good to go. Check it before wasting more time. Bench bleeding is a good idea, but take a look at the main line running to the rear tires. I have the front brakes good, but because that line is bad, you can't really adjust at that point. Also, you should only have 1 full tire rotation. Remember that brakes will feel spongey at first, when there done until the shoes seat in. Give that a try.
Posted: Tue Mar 06, 2007 04:35 PM
the last resort would be using the 'E" brake to stop Shocked
I DO NOT recommend it. only in emergency situations...like when youre cut off and the brakes fail Embarassed
dang pedal retainer clips....... Rolling Eyes
1 LittleBaja 2254 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2095 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3089 Re: Brake light switch...
 Sun Nov 17, 2013 07:21 PM
24 vwboat 10855 Re: lifted spindles an...
 Fri Mar 22, 2013 08:58 PM
what are yall's set'ups
7 vindeta 14285 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
