Latest: xbluegto
Overall: 3573
Visitors: 143
Total: 143
12: Event Calendar
19: Event Calendar
25: My Account
28: Event Calendar
30: Pictures
37: Event Calendar
63: Event Calendar
65: Event Calendar
86: My Account
89: Pictures
132: My Account
138: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Engine cover
Engine cover
Post Post subject: Engine cover
Posted: Thu Feb 22, 2007 04:58 AM
So, what's the best way to mount one?
Post Post subject: Re: Engine cover
Posted: Thu Feb 22, 2007 05:50 AM
EVERYBODY HAS DIFFERENT IDEAS IM SURE I USED RIVETS MAKES FOR A CLEAN FINISH WHEN PAINTED AND ITS NOT LIKE I,LL EVER HAVE TO REMOVE IT. IF YOU DO JUST DRILL OUT RIVETS .THEN RIVET IT BACK ON USEING SAME HOLES!!
Bubba
Bubba
Posted: Wed Feb 28, 2007 03:57 AM
I used stainless steel screws and it worked great. Just be sure to use #8s so that you can use bigger screws if you ever stip them out. I put just 4 in mine and haven't knocked it off yet. I suggest you stay away from bondo if you had thought about it. My brother's was done that way when he bought it and he hates it. Plus if you're ever going to put on a 2 barrel you'll need to be able to remove the cover cause it's a pain if you can't.
Posted: Wed Feb 28, 2007 04:22 AM
you guys talkin bout the rear scoop ?
Posted: Wed Feb 28, 2007 05:02 AM
Yep, we're talking about the rear scoop. The cover that goes just below the rear window.
Posted: Wed Feb 28, 2007 05:12 AM
thought so!
i just used 2 1/2" long self tapping hex drive screws.
Im just lazy Mr. Green
Posted: Thu Mar 01, 2007 12:02 AM
Hopefully with silicone around the threads?
I guess I'm looking for a less permanent solution, that looks good.
Bubba
Bubba
Posted: Thu Mar 01, 2007 02:12 AM
Now that I think about it you might be able to use twist type hood locks.
Most racers use them for alot of body panels, but the cover might be to thick.
azhunter
azhunter
Posted: Thu Mar 01, 2007 03:45 AM
Copperstate sells 1/4 stainless rivets that look good. There's also aluminum rivets that look good. You just have to have the big rivet gun.
Posted: Thu Mar 01, 2007 04:34 AM
DID SOMEONE SAY RIVETS??????????????????
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 369 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 954 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 1584 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 1811 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 3943 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
