Visitors: 110
Total: 110
02: Event Calendar
07: Event Calendar
15: Event Calendar
23: Event Calendar
26: Event Calendar
31: Event Calendar
51: Home
61: Pictures
93: Contact Admin
98: Event Calendar
100: Pictures
109: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Fuel line WHERE?
Fuel line WHERE?
Post Post subject: Fuel line WHERE?
Posted: Wed Feb 28, 2007 03:16 AM
Ok, so I spoke with my VW buddy about changing the stock fuel line that runs through the "hump". I didn't like what he had to say about that. It's mounted via clips inside the hump and the only way to get at 'em was to drill all the spot welds from the bottom. No! No! No! No!!!! No! No! No! No!!!! No! No! No! No!!!!
I don't think so Tim!
What do you guys do? What about running braided hose type fuel line and letting it just lay inside the hump? Wink
Post Post subject: Re: Fuel line WHERE?
Posted: Wed Feb 28, 2007 03:27 AM
I RAN MINE ALONG SID THE HUMP ON PASS SIDE THERE ON THE FLOOR ALONG SIDE THE HUMP, WENT TO PARTS STORE AND BOUGHT A LONG PIC OF STEAL BREAK LINE THEY HAVE DIF DIA.ALSO! BEND IT TO FOLLOW HUMP, TIE IT DOWN WITH SCREW ON WIRE CLAMPS, THEN USE A CAULK GUN AND RUN A BEAD OF SILACON OVER IT , THINK ABOUT IT WHERE DO A RAIL RUN FUEL LINE?
Posted: Wed Feb 28, 2007 04:19 AM
you can run a new line through the center hump. just cut 2 access holes in the side of the hump to feed in/ out the line.
Posted: Wed Feb 28, 2007 06:13 AM
That's about it. Just DON'T RUN IT UNDER THE CAR!!!!!
72BajaBen
72BajaBen
Posted: Wed Feb 28, 2007 07:38 AM
hahaha under the car. well i guess it has been done or you wouldn't have said anything. but man that is funny.
vwbill
vwbill
Posted: Wed Feb 28, 2007 02:59 PM
Yes it’s been done. When I bought my car it was copper line run under the car in the channel and diet to the mounting screws with bread ties. Now it runs on passenger side of tunnel with hold down clips. Mirror image of brake routing on drivers side.
William
Billy
Billy
Posted: Wed Feb 28, 2007 09:54 PM
vwbill, you have a good name Wink That is incredible, I can't believe someone would mount it on bottom. You bottom out and you are risking it pretty hardcore. Oh well, I have seen someone replace their fuses for 9mm bullet shells or something on the samba, lol
Posted: Thu Mar 01, 2007 12:00 AM
Yep, I knew better than to run the new line under the car. Just wandered what folks thought about the braided hose through the hump.
I guess I could run a metal line down the passenger side.
My problem with that approach was it being on the inside of the car and getting nicked or something and leaking inside the car, but I guess it would be better to know sooner inside the car than a leak inside the hump and not aware of it for a long time.
Sometimes I just need a sounding board.
THANKS EVERY ONE!
Posted: Thu Mar 01, 2007 04:55 AM
GO TO THE PARTS STORE, BUY A BIG DIA BRAKE LINE, THEY ARE STEEL & THEY BEND EASLY. DRILL A HOLE NEXT TO HUMP ON PASS SIDE, AS CLOSE TO FLOOR AS POSSABLE.YOU WILL COME OUT RIGHT AT THE STOCK TANK OUTLET LOCATION, FLAIR END OF STEEL LINE THEN CONNECT RUBBER FUEL LINE FROM IT TO TANK. GET A LONG ENOUGHT STEEL LINE TO FOLLOW HUMP BACK UNDER REAR SEAT THEN THRU BACK FIRE WALL DRILL OR USE HOLE ALL READY THERE, FLAIR LINE. THEN AGAIN USE RUBBER FUEL LINE FROM STEEL TO FUEL PUMP. THEN I SLPLIT A PCS OF HOSE ABOUT AN INCH LONG,WRAPPED IT AROUND STEEL LINE WHERE IT GOES THRU HOLES AND SEALED IT WITH SILICONE, I HAVE RUN THIS STYLE.FUEL LINES ON RAILS, BAJA,S & STREET BEETLES. HELL IF YOU LOOK IN MY BAJA RIGHT KNOW YOU WIL SEE THIS SETUP. BUT ONY IF YOUR LOOKING FOR IT , YOU CAN,T TELL ITS THERE AND THERE IS NO WAY YOUR PASS OR ANTHING IS GOING TO DAMAGE IT ANY WAY ,GOOD LUCK WITH IT!!!!!!!!!!!!!!!1
Posted: Thu Mar 01, 2007 04:45 PM
If I were to run it through the inside of the car, I would use these:
store.summitracing.com...toview=sku
to go through the front and rear firewalls. This tubing:
and these tubing nuts:
with the corrosponding sleeves. Clamped securely to the tunnel.
No open holes, no chance of chaffing. Lasts a long time, never had to replace in past race cars.
Posted: Thu Mar 01, 2007 05:07 PM
SCHWEET!!!
Thanks DONT
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 2065 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 4011 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Line X 4 JVAZ 2751 Re: Line X
 Wed Aug 11, 2010 07:29 PM
JVAZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 2249 Re: Fuel pump failure
 Mon Nov 02, 2009 07:57 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion got a line on thing suspension parts... 1 kyle_pc_75 2378 got a line on thing su...
 Tue Sep 01, 2009 02:35 AM
57baja View latest post
