Latest: ecthemc
Overall: 3567
Visitors: 129
Total: 129
46: Pictures
53: Event Calendar
63: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cutting metal
cutting metal
beginnerbaja
beginnerbaja
Post Post subject: cutting metal
Posted: Wed Feb 14, 2007 04:42 AM
Hey there.
Beginner Baja here. Some of you may have read my post in the new members section. Anyways. I want to do a baja as a project after I get my car running. One of the first things I figure I should ask is, where do most people cut off metal and how much do they cut off?
Post Post subject: Re: cutting metal
Posted: Wed Feb 14, 2007 05:31 AM
usually you trim the rear around the engine out. then the fenders if desired.
beginnerbaja
beginnerbaja
Posted: Wed Feb 14, 2007 07:43 AM
What about the front end? is there any cutting there? Or do you only have to take off the front apron? Mainly what I want to know is how to make the fibreglass hood fit for a bugeye kit.
Posted: Wed Feb 14, 2007 01:47 PM
if ya buy the 7 piece fiberglass kit/ or 1 piece front end, then you remove the front apron.
Posted: Wed Feb 14, 2007 03:23 PM
have a look at Chirco's project Chirco Project Baja
Posted: Wed Feb 14, 2007 04:15 PM
That shows for a one piece frt end. The 7 pc kits, require cutting, fitting, triming etc. I have read most of the kits have a templet to get you close.
Posted: Mon Feb 26, 2007 05:56 AM
I am now in the same boat. Anyone? My parts were used, and no template.
Posted: Mon Feb 26, 2007 08:58 AM
You eye ball it Bolt the parts on to the car the best you can and then use a marker to draw your cut lines. leave about a half an inch extra so you can fold the metal over and make the sharp edge smooth and keep it from flexing.
Best tool for cutting is a basic jig/skill saw with a 32 tothe metal blade. Cuts like better.
Tip always leave a little extre if you cut too much your SOL unlles you can weld
Posted: Tue Feb 27, 2007 04:38 AM
Thanks. I did it tonight. Looks good. I appreciate the help.
Posted: Tue Feb 27, 2007 05:18 PM
Congrats on getting it done! Seems like with a lot of projects, the hardest part is getting the nerve to take a saw to the car, once you are in the process it isn't too bad!
Posted: Tue Feb 27, 2007 08:15 PM
kinda like the first time you were with a girl!! all nervous and unsure of what to do Razz Wink
great job gettin it done!!!
Billy
Billy
Posted: Sat Mar 03, 2007 07:16 PM
Theres some great links and how tos here. Just play around, you'll find some good stuff usabug.varton.com/
No new posts VW Volkswagen & Baja Bug General Discussion Guide for cutting up sheetmetal 6 Ravewolf 3027 Guide for cutting up s...
 Sun Jan 18, 2015 10:36 AM
No new posts VW Volkswagen & Baja Bug General Discussion Solid Metal Dash
What year did they switch to plastic trim
3 MrSchaeferPants 3630 Solid Metal Dash
 Thu Mar 10, 2011 09:13 PM
No new posts VW Volkswagen & Baja Bug General Discussion cutting up your bug to baja it 4 cyberjaw4 1715 Re: cutting up your bu...
 Tue Dec 23, 2008 12:13 AM
cyberjaw4 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rustoleum Rusty Metal Primer and Seam sealer?!? 2 zx10r203 2154 Re: Rustoleum Rusty Me...
 Sat Mar 29, 2008 02:49 PM
No new posts VW Volkswagen & Baja Bug General Discussion Cutting holes for gauges 5 az350x 2353 Re: Cutting holes for ...
 Sat Jan 19, 2008 01:22 AM
VIN70 View latest post
